Hey
Both drivers and passenger power windows were working fine, I didn't touch/change anything at all and then just a few days ago the passenger window stopped working
Doesn't go down from the passenger side power window switch or the drivers, doesn't make any noise or anything either so I'm assuming its not jammed/stuck
Has it happend to anyone else?
What was the problem?
Is this a common problen with R32s?
Few years ago my cousins passenger window wouldn't go down in his R32 but you could still put it up/down from the drivers side switch so just his switch was broken on the passenger door..
Anyways - any help would be apprecaited
Thanks
-abu
https://www.sau.com.au/forums/topic/217356-passenger-window-not-working/
probably a relay box problem.
if it is, get your soldering iron out, its an easy fix.
this is a fix for the r33: http://www.skylinesaustralia.com/forums/R3...er+window+relay
one would think it would be pretty similar to the 32. Can't hurt to take your door trim off and have a geeze!
yeah, it will be the relay box. similar thing happened to me on my 32, replaced the power window relay box and it was all good. the one box controls both windows, its located on the drivers side door behind the trim, up the door latch end. you cant miss it.
I had the same problem in my R33, but it made a clicking noise like it was trying to move but just didnt go up or down.
Wouldnt work from passenger side or drivers side buttons so it sounds like its something that happens in all models.
Hope you get it fixed with no dramas :P
Edited by Snoop74
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
