Clearing up the garage floor, i have from R32 GTR the following.
Nice Twin turbo set up, in very very good conditition, minimal shaft play,
no noticable chips on blades, from a clean unmoddified R32 engine, didint even apear to
have been boosted engine unopened.
comes with as pictured.
both turbos,
both dump pipes and manifolds,
turbo pipe (missing badge)
inlet pipes
oil lines,
cooler lines,
some bolts missing, easy to get hold of,
maifold, turbo pipe.
asking a very cheap $380
AC compressor,
good condtition, not noisy works as it should.
asking $160
Front drive shafts and transfer shaft,
good for rebuild, 1 shaft has a split boot,
and 1 shaft missing cage and bearing retainer,
other than that they are in good order good to buy to rebuild
and reft back on your car less time off the road.
asking $120
GTR gearbox,
missing transfer case and push assembly,
in very good condition, does not crunch or whine,
no leaks drove very nice, was emoved to do a mod and
make it rear wheel drive only, became lazy nad just bought a GTS-T box.
no problems at all with it other than th missing parts.
asking $380
Edited by luvsit
https://www.sau.com.au/forums/topic/217392-r32-mechanicals/
  • 3 weeks later...
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
