Group Buy: 60mm Ams Gauges (gotten A Great Deal For You Guys)
for the boost gauge does it come with a map sensor? or is it inbuilt into the guage itself (ie you still have to run a vac line to the gauge)?
it says that they are accurate (what gauge maker wouldnt say that haha), but are the ok for the price or are they bloody spot on in their readings?
  • Replies 59
You need a vacuum to the gauge.
And this picture will show you what you have to fit the boost gauge.
Cheers.
so when will this deal be happening?
I'll end this gb by the end of next week. after that payment will be discussed and gauges will be shipped to you people in about 2 weeks from then.
everything will be arranged again.
Cheers.
Hi mate,
just wanna finalise my order
series2 gauges, Illumination color in blue with black watchcase
- Water temp.
- Oil temp.
- Oil Pressure
- Tacho
- water and oil adaptors as well
shoot me pm with all detail so, i'll make some deposit
Cheers
Ill grab S2
BOOST PRESSURE BAR or PSI
WATER TEMP 50-120℃
OIL TEMP 60-150℃
OIL PRESSURE 0-7kg/cm2 *can this come in PSI?
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
7 gauge covers (want a spare one)
no adaptors for the water or oil posted to vic 3976
i'll have s2 gauges with blue lights and black casing
water temp with adaptor
intake tempx2 one in red light
air/fuel
voltage
5x covers
do we need any sensors for intake temp or do they come with sensors
cheers mitch
Ill grab S2
WATER TEMP 50-120℃
OIL TEMP 60-150℃
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
sorry mate, the oil pressure doesn't come with PSI.
please let me know also what color LED you prefer and what color watchcase(black or silver)
please let me know asap as this group buy will end this week.
air/fuel
voltage
5x covers
cheers mitch
the intake temp will come with the necessary sensors already.
you only need water adaptor for your water temp gauge.
Cheers.
Note: this group buy will end this week and will be process next week.
This Group Buy will end when the clock strike 12am tomorrow night (23rd May 2008)
Those who have ordered, I've sent a PM to you and please get back to me asap.
and for those who haven't order, and want to be included in this group buy. Please let me know by latest, tomorrow 23rd May 2008, 12 midnight.
Cheers.
Cheers.
i have no pm.
pm sent
Guest
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
