Item: GTR Interior Series 3
Age: around 9yrs guessing
Condition:Excellent
Price:$1600
To Fit: (What car)R33 GTR or GTST
Contact:PM me
Comments:I bought these from just jap approx 15months ago and have had them in my GTST straight bolt in fit look great and comfy, front seats give extra space for taller people. Can put pics if needed
https://www.sau.com.au/forums/topic/217836-r33-gtr-series-3-complete-interior/
  • 1 month later...
Condition:Excellent
Price:$1600
Contact:PM me
Hey mate do you still have this interior?
bump and PRICE DROP
Condition:Excellent
Price:$1400 ONO
Contact:PM me
its the front and rear seats, the front door trims and rear side trims
there should be pics that i posted earlier in there
can i get some pics of the front door trims, and the rear of front seats and bottom part
cheers
cheers
i can post pics of the rear of the front seats, cant post the door trims as yet as they are still in the car which is at smash repair getting hail damage repaired.
that should be ok. mainly after the seats anyway
  • 4 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
