Hey,
any one out ther etried the Falken FK451's ?
in particular on standard R33 GTSt rims?
they seem like a really good tyre, but I was told that the Falken tyres are alot better in the larger/wider tyre sizes... can any one confirm/deny this?
I was looking at just replacing th estock the stock tyres on the stock rims, but not too sure... any other suggestions?
Also, just to confirm... R33 GTSt stockies are 16*6's y/n?
I've been told 16*6's and 16*6.5's... and I'm too lazy to take the wheel off :D
Thanks
https://www.sau.com.au/forums/topic/21792-falken-fk451s/
I saw these 2 threads... and other stuff from other forums and on the net... just a bit worried about putting them on the stock rims though.
Ah well, I'll give them a whirl and see how they go, got about 1 mm on the back and 2mm of tread on the front... have to bite the bullet and find something soon!
Thanks,
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-462774
they are alright for performance, only noisey and have bad ride quaility.
they are all the same as they made with same compound, size won't affect the quaility.
The only reason most ppls with big rims having them, is because they are the cheapest performance tyre which have LARGE range of size.
most of the brand only sell their TOP of the range performance tyre in low profile 17/18 or even 19. but falken have all of them even with the lowest range
stock rim should be 6"5, fit 225/50/16
but i heard some one fit a 245/45/16, not sure though.
hope that help
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-463264
Well Fk451 are not too bad but have you ever thought about the ST115s? These are basically street Azenis rubber that have a soft compound but are great at giving you feedback and stick really good too. There not that much more then the FK451 but are heaps better when it comes to handeling and they have very little tyre noise too. Hope that helps mate.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-469892
Really good JimX. Wet or Dry, i have found these tyres extremly good. Even in the wet they have the same amount of feedback as in the dry. Heaps better then the FK451. Only down side is that they might wear abit qiuk due to it being a softer compound but that's the price you pay for having good tyres.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472153
I'm used to having soft tyres. I need to replace the rear on my motorcycle every 6000km or so @$300 a pop. I think I'll try the ST115's, especially since they were cheaper than the FK451's (unless the shop guy got the prices wrong when I rang).
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472346
Is $280 per tyre for ST115 in 255/40/17 a good price? That's what I got quoted from my local Falken tyre shop. The ZE326's and FK451's were both $320 each. Is there anyplace in Sydney that can do better than $280 for the ST115's?
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-472516
I think I stuffed up, I think I confused the prices I got for the ZE326 and ST115 around the wrong way. Which would mean this place sells the ST115's for $310. In that case, where can I get the ST115's for $280 in Sydney?
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-473312
For anyone that's interested, I found out why ST115's have low road noise. According to Falken's American site, the ST115's have "Base tread rubber compound contains micro vacuum capsules that literally suck up road noise". I'm assuming that this also means less rubber hence they wear out quicker.
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-483291
Going off reports on both I don't think they are worth the price difference. But this is only a rough judgement call based on other people's opinions, there's no way to tell unless you've test-driven both yourself. If I had lots of spare money I'd buy the best tyres I could but I can't so I'm going for the ST115's or FK451's (probably the former).
https://www.sau.com.au/forums/topic/21792-falken-fk451s/#findComment-492475
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
