Item: SSR Professor SP1 - Black
Condition: Used but in excellent condition - no gutter rash!
Price: $2.3K ono
To Fit: R32,33,34 GTST, GTT, S15
Contact: [email protected]
18x8.5 +35 ; Falken FK452 235/40/18 - 40% thread
18x9.5 +35 ; Falken FK452 265/35/18 - 10% thread
Wheels were on my 34. Will suit 33 or 32s as well nicely. Black with polished dish. Inspections welcome to serious buyers. Pickup prefered. Wheels and tyres, drive away no more to pay! Perfect for factory guards, no rolling needed.
Pm or email if you have any enquiries.
Pics here:
http://www.skylinesaustralia.com/forums/18...-S-t202082.html
https://www.sau.com.au/forums/topic/218019-18-black-ssr-professor-sp1/
  • 3 weeks later...
