Hi Guys
My Power FC is up for sale, hasnt been used by me yet, bought it second hand
Left it sitting in the cupboard for 3 months and never had a chance to install it.
Only comes as the ECU unit itself with no hand controller.
Will update with pics later to show what condition its in, i'm pretty sure you all know what a Power FC looks like.
Asking price: $1200 firm.
Contact me (WiLL) via PM or on 0402 292 385
https://www.sau.com.au/forums/topic/218440-r34-gtt-power-fc-for-sale/
No offence buddy but Access Auto Works on this forum have them for sale for $1550 brand new with hand controller which cost $300 on its own so you might have better luck if your price is a bit lower.
Yeh i was thinking that, but not really in a rush to sell it yet so for now its what it is.
Still for sale, shit me dead if it wasnt so easy for me to pick up this other one would have got yours.. free bump cause its cheap.
Alot more people will want one in two months mate just hold onto it and put it back on the market for 1300 :bunny:
Alot more people will want one in two months mate just hold onto it and put it back on the market for 1300 :)
Ahahah i did offer lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
