def install a guage before you start stuffin round setting it. sure you have it the right way round n in the line 2 the wastegate? ball isnt jammed in the bottom or something silly like that?
i cant believe you would screw it in all the way to see what would happen.
damn man! that would seriously do some bad ass damage to your engine! those turbotechs are savage when bringing theboost on and they work.
it was probly running 25psi or something silly like that.
take to get it dyno'd and check the afr's as well because you could stuff your engine otherwise.
also buy some bcpr7es spark plugs and gap them to .8 before you go there.
No worries, thanks for the help, I'll just keep it in for now and not boost it. Definately will buy a gauge tomorrow.
i can't beleive you installed and tested the boost controller without a boost guage! you could seriously do some damage to your engine.
your car is likely to splutter due to ecu fuel cut because of free boost or very high boost. remove the controller and ensure you install a boost guage before you start fine tuning the boost controller, otherwise you may damage your engine.
also, i wouldn't advise running more than 12PSI without a dyno tune because your car may lean out.
cheers,
dave.
Edited by dmr
Yeah I definately stuffed up, I know that the more you screw it in the more boost you will get.
I took it out now, it's running stock boost.
I've run into another problem though, as soon as the car hits 5000 revs and over it sorta dies in the ass. I think it may be leaking boost or something. It's been doing this since I installed my front mount. Has it got anything to do with my HKS SSQ BOV?
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
