Item: Trust intercooler single entry 100mm core
Age: 1 year
Condition: Used
Price: $1250
To Fit: (What car) R32 R33 R34 GTR any car really if you can make it fit.
Contact: 0405901010
Comments: Good condition, been used on a street car, bought a twin entry cooler
Item:R34 GT-R inlet plenum comes with throttles
Condition:Very Good 18k klms
Price:$750 $650 $550
To Fit:Any GTR, GTS-t, GT-T
Contact:0405901010
Comments: Stock plenum and throttle plates
I DO NOT ACCEPT LOW BALL OFFERS! ENQUIRE IF GENUINELY INTERESTED AND HAVE THE FUNDS TO PURCHASE.
Edited by F u r i o u s
Age: 1 year
Condition: Used
Price: $1250
Contact: 0405901010
how thick is the core? 100mm?
what else is needed with the hks 2530's to install? liek gaskets etc? or does it all come with everything needed to be fitted.
thanks
as you can see they come with the return pipe, nuts and gaskets on the back of the turbos, should bolt straight on.
hey mate,
just wondering if you are an actual trader or not ?
by the looks of your pics it looks like you deal in secondhand parts?
rob
Age: 1 year
Condition: Used
Price: $1250
Contact: 0405901010
Item:R34 GT-R 6 Speed Gearbox with transfer case, clutch and flywheel
Age:2000 model V Spec
Price:$3300 $3100
Contact:0405901010
Comments:Selling due to upgrade to Dog box, dont want to break original getrag box. Never raced, used as a weekend car until end of engine build which will be taken over by dog box.
Willing to freight anywhere in Oz for $100 on pallet secure freight insured.
Price:$750 $650
Contact:0405901010
Item:HKS 3037s twin kit for GTR came as full drag set up with everything except lines
Age:1 year
Condition:Very Good 2k klms
Price:$7900 $7600
Contact:0405901010
Comments: good condition, great kit makes up to 960hp, good response
Item:Work XD9 18x10 +15 wheels with toyo tyres, RARE BLACK COLOUR
Condition:Very Good condition like new, only been on the car for a month
Price:$2800 $2600
To Fit:Any GTR
Contact:0405901010
Comments: Great wheels, good amount of dish, bought bigger wheels
hahaaha, my car is worked on by C red so the excess parts from building my car are in their workshop as the build has been going on for almost 2 years, so no i am NOT a trader.
reason for sale are
standard manifold = bought hypertune manifold
2530's bought a while ago and wanted bigger turbos, reason for 3037s kit, but now i want something else...
wheels, as you can see in the wanted thread i want a set of 18x10 or 10.5 TE37's....
Standard box, because i just bought a dog box...
trust cooler, because i bought a 160mm trust twin inlet drag cooler...
thanks.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
