Hi guys. im just about to install new gt2860 turbos on my gtr and am after a set of hks dump pipes. so if anyone has a set lying around that you want to get rid of post me or give me a call on 0421701885 thanks Jordan.
Hi mate, we have brand new HKS Dump Pipe Kits in stock for GTR, as well as kits from Tomei, HPI, X-Force & JJR.
Please check out out website via the URL below, where our entire range is available for purchase online:
http://justjap.com/store/home.php?cat=276
Cheers,
Steve
