hey dude i'm in vic and i just recently did the same conversion in my 32. i just told them i blew up my old engine (rb20det) and had to put a new engine in (rb25det). All they asked for was the recipt for new engine and to veiw the engine number in the car (to make sure it wasn't a stolen engine, i would imagine). Oh and i just said it was the same sort of engine to avoid questions about having a bigger engine.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3860767
So did they pull you up on the engine number, because you saying that its an rb20, with an engine number rb25xxxx is likely to get you in trouble. its an increase in power and capacity so most of the time you need an engineer's cert. but thats just in vic, cant comment on other states.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3861820
Nah not at all, 20 or 25 same thing to a stock person haha. you have to remember that 99.9% of people wouldn't know that r32gtst's come standard with rb20det's and r33gtst's come standard with rb25det's. so unless the person viewing the engine number is a mechanic that knows alot about skylines then i'd think you'd be pretty sweet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864212
It worse than that. 'Stock' people (what, like they're friggin' cattle?) wouldn't know what the noise is coming from under the bonnet.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864247
Soon as an officer pulls you over - off the road you'll go with the illegal engine conversion :P
Police know what it all means. And can see if you've been engineered or not, if you haven't, bye bye :(
I know quite a number of people who've been instantly put off the road for that kind of thing.
https://www.sau.com.au/forums/topic/218843-25-powerd-32/#findComment-3864411
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
