Hey Guys,
Just got a couple of questions about my current exhaust system on my R33 gts-t.
I have a 3inch turbo back but its not exactly "ALL" 3 inch back.
From the turbo, there is a piece about 20cm long that isnt 3inch that is part of the dump pipe. and it appears to be the stock pipe.
If you look at the picture, i have indicated where my 3inch exhaust starts from (Note: picture is not my exhaust its just an example)
After looking at my picture, i have a few questions about my current setup:
Is this stock piece restricting my 3 inch system. If so, by how much? And should i replace it with a 3" split dump/front pipe?
Is a split dump/front pipe roadworthy and "street legal"
Im sure many of you will be able to provide me with advice and the assistance i need :O
Thanks
Edited by Ricos
https://www.sau.com.au/forums/topic/219200-my-exhaust-system-need-helpopinions/
Hey Bud
1. Any part of the exhaust which is smaller than another part, i.e. 3" pipe into 2" pipe, is restricting flow.
2. Yes the split dump and front pipes are legal and well worth getting
It would be a great investment to finish off the exhaust system with a 3" front/dump pipe.
Hope this helps
Hi Rick.
I made 200rw/kw with the stock dump but i would replace it anyway if you can. I just put in a JJR split dump pipe from just jap (cost about $80 i think).
Yes they are street legal, as long as the exhaust is under 90db which will have more to do with your muffler setup rather than the front/dump pipe.
I was stumped when i saw it.
The whole exhaust is 3" except that part. It was like that when i bought it. Why would someone do the exhaust and not change that part and leave that peice stock. Wierd
If i get a new split dump/front pipe, do i need a highflow cat?
I dont no if my current cat is stock or not :S is there any way to tell ?
Thanks for the help so far guys!!
Edited by Ricos
Could i get away with just replacing the dump pipe?
something like this (JJR Split Dump Pipe)
http://justjap.com/store/product.php?produ...=276&page=1
OR
would it be better to replace with this (JJR Split Dump/Front Pipe)
i have read that the JJR dump/front would be better because the wastegate joins lower down the dump, thus minimising turbulence and also, the all in one has less restriction cause there is no flange joining the dump to the front pipe? Are these comments true.
Just trying to work out the better option :O
Thanks
Edited by Ricos
that whole section from turbo to cat in the pic is the stock exhaust.
there is nothing there that is 3 inch .
the stock exhaust is around 2 1/2 inch which is what you have there.
is the rest of your exhaust the same as that?
if so its just a stock system.
thro the lot in the bin and get a propper 3 inch or bigger exhaust from turbo back.
i have probably confused every one
The only stock part on my exhaust is my dump pipe....Everything else is 3inch (frontpip, cat, catback etc...)
As mentioned above that picture was only to demonstrate which remaining part was stock....Its not my actual exhaust
The only thing im missing from my 3" exhaust system is the dump pipe. My dump is still stock for some unknown reason (was like that when i bought the car)
So my question is now whether to replace the dump with a 3" split dump or to replace it with a combined split dump/front pipe (and get rid of my exsisting 3" front pipe)
VS
http://justjap.com/store/product.php?produ...=276&page=1 ----- with the 3 inch front pipe i already have
Apparently the split dump/front pipe is better because the waste gate drops into the front pipe rather than back into the dump. Which cause flow restriction and turbulence.
Just need someone to enlighten me if this is actually an issue or not ? and if so...how much would it restrict flow...
sorry if i have confused every one
Edited by Ricos
I know its a bit more expensive, but I would suggest the batmbl/BOS Split Dump/Front Pipe
http://www.skylinesaustralia.com/forums/Ba...it-t136607.html
http://bosimporting.com.au/index.php?page=...t&Itemid=27
I just got mine today.
I chose this over the JJR one, as the waste gate pipe doesn't come in on the bend (like the JJR one) it comes in afterwards.
But many people think the JJR one is just as good , and obviously the cheapest option is just the get the Split Dump Pipe (- Front).
Edited by Az_StrYdeR
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
