  • 4 weeks later...
  • Replies 46
UPDATE:
Ok so the boys at kamakaze have finished with my car done compliance and RWC needed only a couple of bushes for RWC waiting for compliance plate to come from DOTARS which should be tuesday wednesday the latest then off to vicroads i go the wait has been killing me.
Ok so here is what it has cost me for anyone thinking of doind the same thing
$8600 FOB-car itself from japan
$4200 approx for shipping, quarantine and all duties
$4020 for compliance,transport RWC and Fix things for RWC.
$200 in phone calls to find out the latest LOL(jokes)
$960 Vicroads registered and brand new plates YAY :)
Total $17780
I am using the jap tyres that came with it as they were near new Nankangs give you full details when im looking at it my driveway as well as a crap load of photo's.
For anyone else embarking on their first import journey take my advice if your impatient like me buy local as no amount of phone calls to quarantine the agents or compliancers will get your to you any faster. :D
Close to 18k, that's just too cheap Andy! :P (compared to what I payed for mine anyway).
Regardless, great buy buddy, and I can't wait for you to get it so I can steal your kit :)
At least let me drive it once b4 you steal the kit off it :D
Still waiting on cherry33 for an answer on the kits
Hey Andy D,
Congratz on the car and welcome the Melbourne Stagea family, smallish as it may be :)
I love it how when you buy something people are like "oh why'd u buy it there you could have got it here cheaper blah blah" like that helps anyones cause by saying that sorta rubbish...
Anyway welcome and i hope it drives well for you it def looks the good :sick:
count me in the MSF also ... had mine for about 3weeks now :rant: already looking for more power .... first turbo car .... over stock already !
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
