I'm putting all these rumors to rest.....;
R33 GTST 1993, Manual
THIS CLUTCH WILL ONLY FIT AN OLDER TYPE SKYLINE WITH THE PULL TYPE CLUTCH ON YOUR SLAVE CYLINDER.
Now theres seems to a bit of confusion going on from the last posts about clutches.
Back in May my clutch went....I researched around and sourced a new clutch.
The clutch is rated at 1500kg, heavy Duty Daiken NISSAN PATROL CLUTCH.
This clutch is interchangable with my Skyline and is half the price nearly.
Different name on the box but its the same shit only different price.
The clutch was worth $300.00 from SLACKS CREEK BRAKE AND CLUTCH (See Geoff)
GAVIN WOOD installed the clutch and through out bearing & oil for $290
The feel of the clutch pedal is great. The position of the clutch pedal is great.........just like a new clutch is supposed to behave.
When I drive it hard it doesnt slip or do anything stupid.
I can drop the pedal at 3 g's and the back wheels light up pretty quick.
I highly recommend it if you have a mild to standard liner.
AND Its not 1.2 cm or 0.004mm off the floor !- Come on guys.
Any further poblems or questions u can email me; swordfish19792002 @yahoo.com.au
https://www.sau.com.au/forums/topic/21959-rumors-to-rest-nissan-patrol-clutch/
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
