DAM straight its good to go to a dinner that i havnt organised :D
yeah ... dinner sounds chilled be good to meet everyone properly.. and if damo's there im there! havnt seen ya in a while bud!
**edit** oh and only if thats chilled with you steve.... considering ur my driver and all ;)
just woke up... man my sleeping habbits are bad... damo when u haveing a bbq and a team of muppets fit your intercooler.. seems i was not clever enuf hahaha
He will be there :bunny:
funny its Halfway between Adelaide and Pt Adelaide :(
Where is the Halfway Hotel? cos i am stupid and i dont know :(
  • Replies 473
lol sure there was a cruise somehwhere in this thread. To answer stuff from 4 pages i missed lol, kye, as flick said you and lauren shall be at mine after DA, and you better be at DA, cant remember last time you guys came to drifts.
On the chick talk, its good to have a gf as into cars as you are, they then understand the passion and why your willing to go into so much debt for them, right flick ;)
And it seems we will see come next drift school how well flick can handle a car, so will find out then how well she can drive/slide my baby :bunny:
haha yeah i dont remember the last time i was at drifts either :( the more i watch it the more it makes me want to get another drift car haha
might make it to DA, not to sure. i want to go but ive been trying to save and its not going to well :D
will be at yours though for sure!
Edited by Import S13
can i too have a PM about meet spot...
it looks like i might be out for tea as well.... thats right Madaz, not only will i be lanning with SAU people this weekend, i'll be going for a dinner and cruise!!!!! OMG!!!! what has the world come to??? =)
so is the halfway hotel half way between town and bay or town and hills??
why do they call it the halfway???
and kell i never said i will be there. hahah
dont get hopes up
and steve GOLD pictures espec, the cat and cookie one.
:woot::P:):D:starwars:
:whoops::whoops::whoops::whoops::whoops:
I just booked the HALFWAY hotel for 20 people and SATURDAY night at 6pm it is under Skylines Australia just incase im late, which i probably will as per usual lol
well i will most likely see you at the meet spot kellz
Well most people are indecisive on if they are coming or not thats why i booked for 20 so if people decide on the night that they want to come then there will be room :P
see im a smart little princess :rofl:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
