Nathan you still holding those parts for me?? :P
Hey guys i got a question, considering i already told you im having a cruise for my birthday and ill have my car back.. I wanna order 100 products of anything from bakers delight for a gift for everyone. What should i order for everyone to eat for a snack? Finger Buns, choclate crossants, choc mud scones etc...
xox kahli xox
hey Kahli i work at balfours and im the supervisor of the donut section so i mite be able 2 get a great deal 4 u on choccy donuts 4 ya bday cruise,
  • Replies 473
I'm sure you'd be discrete!
(disclaimer: I am or may not have toyed with Kell's quote)
:P
Dear God,
Please forgive me for what I am about to do...
"Who's got the hots for the box with the dots?"
Amen.
Love,
Dohmar
^^ i sooo want a job there
i work with industrial blenders making grout dang what a waste i so often think man i wish this cement was flour and sugar and i was making cakes :):D
I with ya on that one madaz....i work with databases all day and all week i wished they were freaking cakes that i could eat and get done with ;)
but if you get rid of the dots and spots on the box id have the hots for the box, dr spock.
ha ha, i love people who waste there employers time and money, lol
im on holidays so have an excuse :bunny:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
