I'm in the market to buy a new turbo.
I'm looking at either a GT2510 or a GT2530.
I was leaning more so towards the GT2530 as I know it will make in excess of 200rwkw on a RB20DET.
What I don't know is how laggy they are.
I do know that with the GT2510 that they are rated at around 170-180rwkw but can be pushed to around 200rwkw with them starting to run out of breath up top a little.
(Well thats what I've been told anyhow)
The GT2510 also basically has no lag and is extremly responsive.
Now..
I'm after a street car that is extremly quick from say 0-160km/h.
Would I be better off going for the GT2510 or the GT2530.
Let me know ppls how laggy the GT2530 is if any... :O
It sounds like the GT2510 compares flow wise to the VG30DET Turbo.?!?!?
Thanx... :burnout:
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/
  • Replies 42
go the 2530, both are new bb turbos and will be better designed than the std turbo, you would probably find there is very little difference between the turbos, does the 2530 have a bigger exhaust or compressor housing? The little extra lag will help you get traction when you take off. wouldnt want to change the thing then find the last few rpm are a waste of time as the turbo is out of breath.
Or maybe just go the 2510 then with my new turbo I can smoke you in the top end real easy.
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40379
2530 joel the 2510 is good but as you said its a vg30 turbo that I reckon spools up really early.
you not thinking about the hiflow rebuild of the stock turbo?
cause although they are expensive they seen to get the results!
you will need an hks version of the 2530 as the garret version only comes with a t25 flange I believe. I did some invesigating a while ago in to turbos.
the hiflow of the stock unit didnt sound to bad. I just got a shock on the price though.
cheer
meggala
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40421
I was waiting for your reply Meggala.. :O
I was thinking getting a proposed adaptor made up for it as I have been offered the GT2510 kit which is apparently a t25.
I haven't put much thought in to the rebuild as i've never really had any good luck when getting ppls to rebuild mechanical items.
Always some thing not quite right a rattle here or a grind/whine there. :confused:
It really depends as I can get the 2510 new never used for around $500 less than the rebuild with the adaptor made.
hrmm... You've got me thinking about the rebuild again now.. Less hassles no modifications... DOH...
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40425
Its a tough call I know I still considering it I have the injectors waiting and a z32 afm as well. But I'm un sure I really want more than 200 rwkw from an rb20. I really liked mny vg30 turbo ands I have a sneaky thought that you will like the 2510. but one thing to consider are you going to do the rb 25/30 or is it a hope rather than a dream If you are going the rb25/30 later buy the turbo once and get a t3/4 if not the 2510 will be good. as I said Its a tough decision I'm looking like going for an rb25 turbo with steel wheels If I can or just with ceramic wheel dial in 13.5 psi with the actuator and be done with it. and may be in a year or so get a a wild set up but don't hold your breath for that.
meggala
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40427
wow...
Thanx DLuded ...
No.. I don't think the RB25/30 is going to be done..
It would be nice but I don't actually think the RB20 is that gutless down low well at least not with 25deg timing in to it.
It keeps up with traffic off boost and thats all that matters = fuel economy :O
I would like the top end of the 2530 but.
So tell me meggala is the top end still there or you can feel it drop off with the vg30?
Like at the moment it is as quick and i swear it was slightly quicker than andy's 33 gtr before I done the fuel pump as now it is running richer.
So with a 2510 good ecu remap it should really get up and go, heaps of wheel spinning torque in second?
Or if I want that should I go the 2530? :burnout:
Thanx ppls.. :(
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40633
I have for my car a HKS GT2535 . Can anyone give me any info on this turbo like how much bigger it is than a 2530 and how much smaller it is than a 2540 as you never hear much about this modle. All i have heard is that it should make 350hp in the meat of its eficiency and upto a max of 400 hp and that the 2535 and 2540 are slightly newer then the smaller modles.
JMS have made 220 rwkw using a 2530 so i hope to make simular results or better with a 2535.
Tim
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40798
Hi all,
I'm new to the forum.
JAPSIX -
Basically, the following turbos are listed at their approx. HP levels at the same boost pressure:
GT2510 = 300 PS
GT2530 = 320 PS
GT2535 = 340 PS
GT2540 = 350 PS
GT2540R = 360 PS
The attached graph might give you a little better indication of just how similar the HKS gt25 series are. (but thats a great turbo you have)
Joel -
I'm looking to do a turbo upgrade on my rb20det soon as well. :) Have you considered rebuilding the current rb20det turbo with a GT25 BB core? Not sure how much it would cost but would save having to muck around with flanges etc...
Ash.
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40842
I have looked in to the rebuild using a GT25 BB core from Bill at ATS In Adelaide.
He quoted $2150.
He said that he has tested a few different highflow and turbo setups on the rb20det with Tilbrooks and apparently the GT25 core is the way to go.
I think if i remember correctly that running 1 bar you could make around 210rwkw pretty easily.
But for the price..
Well I can pick up a bran new gt2510 for around $500 less.
And that is a bran new core and I never have really had tonnes of luck with rebuilt mech. items, so in a way i've been put off rebuild turbo's.
Has any one actually had first hand experience with the GT25 core on the RB20det?
hrmm I wonder if I would still have the boost drop problem with the GT25 core..
I probably would need a stronger spring wouldn't I??
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-40977
Joel you are humming and harring quite a bit on your decision.
I think the small amout of lag u will produce wont affect pickup very much between the 2 HKS units its not like your putting in a GT40 :)
U can get used to a small bit of lag but u will be unhappy if your new 2510 doesnt give you results.
For example we just got my mates SR20 2.0 silvia (t25 as yours) hiflowed with T28 Replica steel wheels non ballbearing and his spools way quick and he is gone, i only catch him at 140kmh end of 3rd gear and mine just got dynoed at 201rwkw
He ran 12psi and front mount im spewin but dont tell him that :-)
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41433
I went around to the local ATS, JMS, and Tilbrooks.
This is on a RB20DET:
ATS:
1. HU?? There is no such thing as a GT2510.
2. The max the std RB20 housing made with GT25 Internals and approx 16-18psi worth of boost was 196rwkw with a tuned ecu. Power seemed to drop off up top but he doesn't know why. Should be good for 210rwkw.
3. He would do the GT2530 internals in the RB25 Turbo next time, and he claims it should be good for 210-220rwkw
JMS:
1. ATS's GT25 Internals arn't efficient and need to run to much boost Basically they don't work, it was one of this blokes car's that it was on.
2. He had a Nismo turbo that was a kind of custom job some how ?!?! that was inbetween a GT2510 and GT2530. But it was sold for $1500.
Tilbrooks:
1. He also said that ATS GT25 Internals didn't work in the RB20DET housing and he also said that don't bother with the std. garret as you need to run to much boost to get a decent rwkw GO HKS for $4000 bah.. too much.
(He tuned the RB20 gt25 turbo ATS Did)
2. He told me that I hav't got std injectors.. ?!?!?!
3. Also the Thermo's arn't mounted properly.
Would the std RB20DET housing cause the power to go flat at the top end?!?!
And Do you thing the RB25 Housing would fix this problem...
What a pain in the arse turbo selecting is.
I really don't want to spend 2k on ATS' 2530 internals and find that it chokes up top.
So about my injectors..
They are like a cream colour (plastic bit) with a red dot on them.
STD or Non Std?
Maybe that's why I've always run a little to rich?
The head has also been pulled off previously.
Help PPls...
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41441
will check my injectors tomorrow joel, glad I dont have to make your descision just have to put up with the lag when I put my turbo on.
Could just try and find a sh hks, I know there is a place in the city, on gilbert st i that imports parts and has a small shop and sellstuff cheap. it dosent matter what you do you will probably think of somethink better later just better to jo somethink ond they you cant change your mind.
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41449
Relax !
what about a garret GT25? they have different housings for higher topend flow, u choose which one depending on lag.
The rb25 t28 turbo holds alot more topend than an rb20 t25 turbo does but ofcourse u will feel it in response loss. yes to a degree u will still get a kinda flat curve with standard housing there is only so much air u can cram into it.
All skylines run pretty rich altho if u have a remapped ecu this should of fixed that. yep bigger injectors will make u run richer still......
cheers
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41455
now you know what I came across I had the money for one as well. but guess what it got ear marked buy the missus for something else :) as macka said don't stress to much about lagg.
you will need to think about a small gt 30 if you want it to bolt on or a t3/4 hiflow with ballbearing center.
you could try calling gcg in sydney they might have some idea's
I hate searching for a turbo.
or you could say stuff the lot of you and go get a t04 e with external gate and custom manifold and
:wizard:
meggala
Just buy a vg 30 turbo for 450 and go and have fun
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41472
Excellent info in this thread!
Joel, nice summary of your discussions with ATS, JMS and Tilbrook.
grepin, Chris32 and I were only talking about this stuff at the Autosalon. Someone we know bought that hybrid from JMS and is very happy (although hasn't put it on yet).
Yeah, turbo selection is a real headache because there isn't enough hard data out there that translates to how the motor will perform in the end!
Interesting comments from JMS and Tilbrook about the std Garrett not being responsive enough.
Good luck!
Freebaggin.
https://www.sau.com.au/forums/topic/2197-gt2510-or-gt2530/#findComment-41475
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
