  • Replies 504
Paul,
I will set it up so you can have a look at the proofs on tuesday.............
The girla at HayMarket will give me a call now to organise it all.
I will be e-mailing it to her. All you have to do is go have a look and decide on 400 or 600in numbers.....
can you email me your tell number?
LOL @ Kyles ..... if it was low on you .... imagine what it was like on me .... kinda um hello! :D
My preference was the blue sleeved/ white shirt but in V-neck if we could get it ...... that shouldnt be too bad .... blue sleeves draw attention to upper body i thought :D
We have black shirts already ....... the plain jayne Skyline Australia ones.
Niz, if we stick to the same colour and when they have the logo on them it doesnt matter if we wear different styles. All thoes tops where really wrong for me execpt the singlet.
Just another sudgestion, What about thoes singlets with the built in bras in them. They would look good. Paul could get the print put on thoes.
I know we already have black tops.. Black is good at hiding a few things.
the boys are having blue ....
bras etc get a bit pricey and why have a built in one when you can just take your own - moulded, flattering own :D
Kyles this really has to be on a budget ....we are already over and its starting to comeout of pauls pocket :D
Im not really into my black one .... each to their own i know but Blue is what the boys have got and Blue is what the girls have got ..... maybe if the single was made "all blue" for you would that be a good comprimise? its dark enough to be flattering but still inkeeping with what everyone else has?
understood ...... everyone involved needs to be comfortable .... but as with any promo gig there is a certain amount of skankiness involved ..... the old 'sex sells/ got it flaunt it' i guess. I used to do modelling so im pretty well accepted this fact loooong ago.
Butdark blue singlet should look tops :D
Oh yeah and thats why i want a low cut top, my legs arnt as nice as your legs!!! Thats why the other tops dont do antying for me, they arnt good styles for my shape, lets face it im not that skinni yet, I still have to becarefull what i wear.
I have no probs wearing a denim mini skirt though, just want to show off my "better assets"
hehe well thats why chose top i did ..... i dont have your "upper assets" and trust me im jealous!! ive got choice of either dark demin mini (every skirt looks mini on me tho) or my very short demin shorts that are quite a nice snug fit :D
you legs should look fine least you can wear heels (always flattering on legs) i cant end up looking like friggin giant!!
Im going to go shopping and check out some mini skirts and shorts. I do have a denim skirt thats short but its deffently seen better days (Been a bit worn out) So i need a new one anyways.
Shoes: I have some shoes i call my cinderella shoes, they are clear plastic, pretty cute.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
