For some reason the "Edit" button is not showing on the first post, so here are the specs:
Make:1996 GTR V-Spec
Milage: Less than 4,000kms on current engine
Colour: Midnight Purple
ENGINE
Balanced and Blueprinted bottom end
Forged CP Pistons
Eagle Conrods
HKS Cam Gears
Tomei Cams
Trust Sump & Baffle
ATI Crank Pulley
INDUCTION
Garret 2560-10 Turbo's
Sard 720cc Injectors
Apexi Pod Filters
FUEL SYSTEM
Custom Surge Tank
Bosch 044 Fuel Pump
Sard Fuel Regulator
Braided Fuel Lines
ELECTRONICS
APEXi Power FC with hand controller
Blitz DSBC Boost Controller
EXHAUST
Full Twin 2.5" Kakimoto Racing Exhaust
Tomei 3" Dump Pipes
DRIVELINE
OS Giken 5 speed gearbox
OS GIKEN triple plate clutch
WHEELS
BBS 18”x9” rims
INTERIOR
Nismo 320km/h speedo
Momo steering wheel
6 Point Roll Cage – bolt in
PERFORMANCE
Max power output:
440awkw @ 28psi on race tune
344awkw on street tune
Best ¼ mile ET:
10.5sec@140mph in street trim (including exhaust system on car)
Edited by allblitz
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
