Item: Trust TD06 20G 8CM RB20DET turbo kit
Age: Unknown
Condition: excellent condition, very little play, mani has had very little use
Price: $1500
To Fit: (What car) RB20 or RB25
Contact: Ben - PM, reply in this thread, or ring 0433 535 410
Comments:
Hey all,
Bought this kit for my car recently, decided I want something a little smaller, so it's up for sale.
It's a trust TD06 20G 8cm internal gate kit for a RB20, comes with all lines, cast hot pipe, manifold spacer, all studs etc, Trust cast dump pipe, Adj. actuator etc, ie. the full bolt on kit
VERY good turbo for those wanting big power out of their RB20's, be insane on a RB25.
A Mates R32 was tuned with the same turbo kit, and supporting mods (Z32, GTR injectors, pump, FMIC, exhaust, remap) and made 241rwkw on 16 psi, with 16psi by 3900-4000 RPM, holding boost hard till 8500RPM limiter.
Comes on a bit later, but when it hit's, it hits HARD.
Kit also comes with a DMAX Japan stainless low mount manifold, extra bracing added, not a cheap china mani.
Im chasing $1500 for the full bolt on kit.
Will trade for certain parts. PM me with what you have.
Am willing to send at buyers expense, but beware, it's pretty heavy.
Located in Mile End SA, Contact Ben via PM, this thread or 0433 535 410.
Edited by R31 drift pig
Ok... still for sale.
Have now found out that this was incorrectly sold to me as a TD06 20G 8cm.
It is a TD06 17C 8cm...... rated @ 380 PS which equates to about 225-230 RWKW's.... (in a perfect world mind you) Been said a lot though that Trust underrate their turbos though, so maybe 240 - 250rwkw's
I have no idea what this would be like on a 20, but Id say too small on a 25. I cant find much info on them, and i cant find anyone who's using/used one....
Id also say that this would have less lag that a 20G, maybe some competition for a HKS2530?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
