i got my car in the shop atm getting a turbo installed they said its gonna cost me around $2000 bucks for the installation and dyno because they had trouble making it fit and that they have to make up some pipes to make fit....also injectors and fuel pump does this sound right to you ??????
https://www.sau.com.au/forums/topic/220098-is-this-right/
wat turbo are u puting onto wat engine???
how much piping was needed to be made?
wat trouble did they run into while trying to fit ur turbo ???
its hard to give u a answer with out knowing how much work they had to put into the job to get every thing fitted
hyper gear turbo into a rb25 and they needed to make up oil feeds and a new flange
https://www.sau.com.au/forums/topic/220098-is-this-right/#findComment-3881307
i know of some people who had problems fitting hyper gear turbo's they expect it being a FULL bolt on turbo but it doesnt work out that way
so let me get this str8 all up they quoted u 2g's for
fit turbo
custom intercooler pipe
custom intake pipe
braided oil line with flange plate
fit injectors
fit fuel pump
dyno tune
Edited by STR8E180
https://www.sau.com.au/forums/topic/220098-is-this-right/#findComment-3881311
fit turbo
custom intake pipe
fit injectors
fit fuel pump
dyno tune
pretty sure yer they said they charge more an hour to make parts
https://www.sau.com.au/forums/topic/220098-is-this-right/#findComment-3881320
Japanese bolt on kits fit nicely, usually allowing the average E-mechanic to fit em up in hours.
Questionable Chinese turbos need "massaging" and some fabrication.
Did they initially quote you a much lower price?
yer they said between 500 to 1000 so im just trying to get my head around the exstra grand has come from
https://www.sau.com.au/forums/topic/220098-is-this-right/#findComment-3881347
i think it sounds about right
cool good then i dont wanna get ripped off so many dodge conts out there aye...at least they called me before they did anything ... got my front brake pads done last year and they said 200 for pads and machineing just for front ,whent to pick up ma car and they said i owe f**king $590 and i wouldnt get ma car back till i payed haha so dodge ...dont go to a car place where there all dodge looking mexicans haha
https://www.sau.com.au/forums/topic/220098-is-this-right/#findComment-3881376
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
