Guest INASNT
Got some PFC problems.
I got series 2 R33 and i thing i bough a series 1 pfc as it wont prime the 044 fuel pump long enough to let the car start. Stock ecu primes for around 3 seconds, pfc primes for around 1.
Secondly when we program any setting in and then turn the car off and then on again the setting get lost. I tried another series 1 pfc and it does something similiar.
Any1 know whats going on, and what model numbers would be for series 2.
My PFC model number is PFC RB25 9810-0046
Other model number is RB25 9708-0021
https://www.sau.com.au/forums/topic/22011-pfc-help-needed-urgent/
Guest INASNT
Originally posted by Steve
I dont know if this will help, but have you tried turning off the boost controller option, or checking that it has been turned off?
I have series 1 with power fc and it primes the pump for about 3 seconds, not 1.
what fuel pump u running?
I rang up hypertek today who are the apexi aus dealers and they recon the fuel pump is not communicating with the pfc properly, but mechanic have used this fuel pump and power fc's before and it works. Also they recon that the pfc is in ocked mode and the only way to unlock it is to two the car to their shop with the pfc and then they do a diagonistic test on it with the pfc laptop software they have (and the only comapny in aus with the saftware). They also said that they can tune the car alot better with the laptop than with the hand controller but some1 else i know had their car tuned by them, then went to another well known tuner and managed to get near 40rwkw more using the hand controller.
What to farkin do?
I am running a bosch 044, before that it was stock, no problems either way. I have never heard of a fuel pump not communicating with a power fc, it doesnt have fuzzy logic or anything, just binary swiching? So WTF?
Have you tried resetting the power fc - back to original settings?
It may be worth asking what functions are available throught laptop that arent available throught hand controller, but if you dont need to activate them, why bother with getting them to do the tune. A good tune depends on the guy pushing the buttons, not how many buttons he can push:)
Guest INASNT
ok sorted a few things out, we chucked my pfc on another gts that was there and hey presto it farking started and saved the setting once changed.
So some wiring in my car is farked, coz its not keeping power to the pfc and somehow not working with the fuel pump. I dont think its a fuel pump issue rather something in the loom that is not working properly!!
My climate control also always resets when i turn the car off, so its some connection there!!
any1 know how i can fix this??
FARKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK
Guest INASNT
Here it is: http://www.skylinesaustralia.com/forums/sh...threadid=19278&
Have a look towards the bottom of the page for a post by whatsisname.
i dont think its the plug as we did a check of all the sensors and they r all recieving a signal, i even blew in the air filter and it registered!
Looks like an ignition wire is screwed up somewhere, who knows about the skyline ecu's?
Inasnt, it could be that the wires not connecting, and causing all the trouble, arent related to any sensors? Might explain things.
It would be worth having a close look a the plug just in case. I think it is the problem for a couple of reasons:
a) the plug is the only thing you have farked with apart from the ecu, and you know the ecu works, and
B) it would appear that having a plug fault is not an uncommon event.
all the evidence points to it. Perhaps even try giving the connections a clean and just do a close visual.
In another way, I sort of hope it is the plug, for your sake, as otherwise WTF is it?
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
