I have all genuine BNR 32 GTR gear for sale.
I have a GTR front bar in midnight blue, i scratch down the bottom
Genuine GTR rear spoiler midnight blue, perfect condition
Genuine alloy GTR bonnet, damaged, white, repairable
GTR genuine grill, white, missing a couple clips, (still stay with cable ties) and you cant tell haha
Prices::
Front Bar $600
Wing $300
Bonnet $150
Grill $50
will post interstate at buyers cost
NEGOTIABLE on ALL prices
contact me via pm
help me fund my next project haha (and get off defect)hahaha
Pics upon request
https://www.sau.com.au/forums/topic/220519-genuine-gt-aaaar-gear/
bonnet take a hit from the front, didnt like the speed limit sign (haha) it is fixable, i will get a quote this week.
and yes min prices are negotiable (cheaper if you pick it up) pm me with ur offer ont he GTR bar
i need this stuff gone asap, willing to do cheaper if it is picked up this week, and all items can be viewed when necessary.
thankyou.
yes it is GENUINE hence not fibreglass hence it is PLASTIC
the thing is strong and light, wont dissapoint and rad33, if the bar sells, i will talk to you about the rad support
I WILL TRADE the front bar for a aftermarket style bar,
preferably Do-Luck, i dont want vertex or uras, and cash my way if its fibreglass
tell me what u got and i can work something out.
and i will swap the gtr wing, bonnet and grill for a GT Wing or similar style, (carbon fibre not aluminium)
Hey buddy, just a heads up on the GTR wing. I've got a silver one thats been for sale for half the price and hasn't had any interest yet so you may be asking a touch too much. Either way, it's not mine so it's not my decision but just thought it may be of interest.
Cheers.
thanks for the words but all depends wat state ur located in buddy
coz for u to ship urs sumwhere will cost heaps more then for me to ship it somewhere.
Hey mate did you sell the grill??
got lip but no slots. who needs em anyway ahah there just for show
the front bar pretty much touches my front mount so there is very little space for the air to go anywhere else.
some one buy it.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
