Hi all!
i need opinons!
should i put a wing on my car or not?
i really like the DO-LUCK wing (the purple 34) and i also really like the Veilside wing (the bluish 34)
but i just wanted to know should i put a wing on my car or not?
https://www.sau.com.au/forums/topic/220605-to-wing-or-not-to-wing/
GTR wing with lower mounts FTW :P
Yeah that looks hot. Wings look good as long as theyre a compliment and not a distraction... The lower GTR wings look awesome imho, I'm not a huge fan of the other two due to the trailing fairings on the sides. Not a fan of drift wings either...
Yr car looks pretty good atm, you'd wanna make sure its a complimentary addon...
-D
ive been looking for a slime boot lip spoiler. cant find em. I dont mind them spoilers above on the right cars. I cant find decent spoilers anywhere tho. let me know if u find anything.
Ill keep mine with no spoiler. does look sleek
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
    • Have you noticed if the squeak changes with temperature or after driving in the rain?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
