  • 5 weeks later...
Hey guys,
Got a cluster issue, every tacho works fine besides the rev tacho, it doesnt give the true reading and just jumps whereever it wants
Am i looking at a new cluster? or is this a simple fix?
I have the same problem!! Someone must know??
  • 3 weeks later...
  • 1 year later...
have u tried checking the connection in the back of the cluster to see if its loose or dirty? would start there i have same issue and its where ill be starting. im not in a rush though its only a tacho
Edited by chubs
yeh i'll have a look if its loose or something but it radomly still works every now and then..true its only a tacho buts its annoying to see it going crazy
yeah it is abit annoying lol with mine if i hit the dash a lil it usually works again but with bumps on the road it dies. should be an easy fix i know tacho and speedo are pretty common drama in 33's though from what i have seen.
bump this up.
k guys. my tacho stopped working thru a track day.
it will work when warming up but after a while it fails and drops down to 0.
if i hit a bump it will jump up...then back to zero.
My Power fc handcontroller tacho works fine......it leads me to believe its a wiring issue behind the cluster.. However it is all fine!!??
i have also replaced the whole dash cluster and this EXACT problem still persists. i have also checked all my fuses.....and they are fine
ANY HELP OUT THERE GUYS.??
i have used contact cleaner to clean the ecu pins, and the ignition module in the engine bay, and still hasnt fixed the issue.
its getting VERY frustrating !!!
i havent found a proper fix yet for my tacho but i notice by taking of the plastic cover off and pushing my gauge on the bottom right corner of it, it will work again. maybe i need a new tacho but i'm gonna drive around with the plastic cover off for now untill i get a new tacho. Not sure if it will work for you cuz my one was just shaking all over the place.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
