  • 5 weeks later...
Hey guys,
Got a cluster issue, every tacho works fine besides the rev tacho, it doesnt give the true reading and just jumps whereever it wants
Am i looking at a new cluster? or is this a simple fix?
I have the same problem!! Someone must know??
  • 3 weeks later...
  • 1 year later...
have u tried checking the connection in the back of the cluster to see if its loose or dirty? would start there i have same issue and its where ill be starting. im not in a rush though its only a tacho
Edited by chubs
yeh i'll have a look if its loose or something but it radomly still works every now and then..true its only a tacho buts its annoying to see it going crazy
yeah it is abit annoying lol with mine if i hit the dash a lil it usually works again but with bumps on the road it dies. should be an easy fix i know tacho and speedo are pretty common drama in 33's though from what i have seen.
bump this up.
k guys. my tacho stopped working thru a track day.
it will work when warming up but after a while it fails and drops down to 0.
if i hit a bump it will jump up...then back to zero.
My Power fc handcontroller tacho works fine......it leads me to believe its a wiring issue behind the cluster.. However it is all fine!!??
i have also replaced the whole dash cluster and this EXACT problem still persists. i have also checked all my fuses.....and they are fine
ANY HELP OUT THERE GUYS.??
i have used contact cleaner to clean the ecu pins, and the ignition module in the engine bay, and still hasnt fixed the issue.
its getting VERY frustrating !!!
i havent found a proper fix yet for my tacho but i notice by taking of the plastic cover off and pushing my gauge on the bottom right corner of it, it will work again. maybe i need a new tacho but i'm gonna drive around with the plastic cover off for now untill i get a new tacho. Not sure if it will work for you cuz my one was just shaking all over the place.
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
