Japanese cars are electronically limited to 180km/h - this is why they all have 180km/h speedos.
You can get speed cut defenders which will remove the limit.
Anyone know how fast it would go without the limiter? My guess is 240-250ish (it does have a low Cd)
Edited by MaXiMuS007
my mate the other day in his 350z hit 230km and it wanted to keep going so perhaps around 250 maybe more...
has anyone tried to take their v35 over 180?? does it speed limit and loose power?? what happens
I found that it went about 8 Km/h off the end of the dail, before it hit "the wall". Nothing dramatic, still smooth, just stops accellerating.
On the track, the car gets to 180 quite easily and I would guess it's got a lot more in it. From memory it was around the 4500-5000rpm range in 5th gear. I've done a cruising lap where it was in 6th sitting at just over 3000rpm doing 160-170km/h
I've done twice top speed on my v35, it's speed limit. u will feel the power banned even you hit the pedal.
Non-JDM 350Zs have a 250km/hr speed cut. I've hit 243 (speedo indicated) before, and that was a struggle to reach even though I was near peak torque.
Theoretical top speed is around 300km/hr with a 6MT, if you crunch the numbers and calculate with a 6850RPM fuel cut. There's no way a NA FM platform car is going to reach it though.
look at the gear ratio for 6th gear (in a manual), and cross reference it with the known rev cut in the car: it will give you the theoretical top speed, ignoring friction, wind resistance, etc...
Gotcha...
Engine Speed to Speed of Car:
v = 2πrω/Ggk
where:
v=velocity (m/s)
r= radius of tire (m)
ω= engine speed in rotations/sec
G= final drive ratio
gk = k-th gear ratio
Assuming 6MT with 18" wheels & stock tyres, theoretical top speed = 300.1264km/h!
I've spent far too much time this afternoon trying to develop a spreadsheet to do the top speed calcs. The calcs are based on a 6MT on 18s and the spoiler (Cd=0.28).
I can't find any firm data on the frontal area of the vehicle, so I have assumed Ap=2.5m^2.
The theoretical maximum speed is ~308km/h based on the peak power figure alone. Obviously this will be limited by gearing and air resistance.
The maximum real speed I calculate is 281.02km/h... this corresponds to 6150rpm in 6th gear. Air density is assumed as 1.204 @ 20degC.
FYI, if the frontal area is actually 2.8m^2, maximum speed reduces to 269.65km/h.
Lower temperatures (higher air density) will also affect these figures.
I was considering putting a 3.9 final drive in my diff, so I had a look at how it would affect my in-gear speeds.
This table provides the data, although it does need to be updated for the HR engines' cutout and the possibility that some FI guys might want to run the 3.2 final drive out of the auto diff to make more use of their wide spread of torque. I know, if I was going TT, I would.
I have a gt-8 and have done a couple of runs recently to test exactly that for my own curiosity.It certainly wasn't limited at 180 and still had heaps left at 210,but ran out of road.i will say it gets there in no time as well.
If anyone is interested, I've attached my top speed calculation spreadsheet. Defaults numbers belong to a 2003 6MT 350GT. Spent WAAAAY too much time on it.
Feel free to play around with it as you wish. It should work for any vehicle (with a maximum engine RPM of 8600)
Speed_Calcs.zip
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
