Hey guys
Ive managed to get some kind of oil based substance to stain my passenger and rear quarter windows, resulting in some bloody ugly and obvious streaking. It could be any of the following things: WD-40, Car Polish, Cut & Polish, Wheel cleaner... maybe something else but I cant remember. Lesson here? Fkng use clean cloths when you wipe your windows!
Anyway - ive tried the following to take it off, with alot of bloody elbow grease:
-Hi Pressure water jet
-Turps
ACETONE (How this didn't work is beyond me)
Finally i resorted to a tiny piece of 2000 grit sandpaper in the bottom corner to see if it really was removable at all, and turns out it is. With the water I dipped the paper in it turned into that bluey pinky reflective oil colour, telling me whatever is on there is oil based. I cant take sandpaper to the whole window though, thats just asking for trouble. Nothing else will phase it though, it just wont budge!
Is there anyone with a bit of know how able to shed some light on something I can try? Would a glass co. like OBriens have some kind of wacky polish to get it off I wonder.. I remember them saying a while ago that they can't polish curved glass... any thoughts? I'd really love to NOT have to replace these windows...
Thanks in advance!
Andrew
Edited by Sol32
I wouldn't be using acetone or sandpaper thats for sure...
vinegar and newspaper to clean your windows...
or to remove crap use some metho... I clean glass and panels with metho before applying vinyl graphics to be sure the surface is free from oil, dust & grease...
Does it look similar to my problem? :ermm:
I took it to Protech carcare, which used some solvent which removed the obvious colouring but it was still there, especially when sun reflect off it.
Final Inspection says they can remove it, I think they mentioned polishing the windows.
wow that is some hefty staining or something...
If they are just going to polish it use some cutting compound on it, go crazy on it...
Does it look similar to my problem? :)
Go buy some polish and a buffer... Hit your windows..
Maquires paint cleaner works on almost anything and then you can also use Auto glym window polish (which is shit IMO) I have similar wet spots but they cannot be removed. will need to buff them out.
My brother is a tinter and to get old tint off they use very fine steel wool. Doesn't make a scratch on the glass surface, but peels glue, tint and other gunk away pretty awesomely, maybe try something like that?
I'd say that sounds like the most plausible way of getting it off - is this by hand or with a buffer? Also where stocks it?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
