Ok so my DVD player recently decided that it wouldnt read any DVD's anymore, Im pretty sure its because it is about 3 or 4 years old now and the laser has crapped itself.
I hear that DVD players, CD players etc have a life of about 4 to 5 years (depending on how often you use them) because the laser eventually degrades to the point where it wont read anymore.
Firstly - Is this true?
Secondly - If I use my PS3 as my DVD player aswell as for playing games will it decrease the laser life significantly (I do watch a fair amount of DVD's) or am I being paranoid?
https://www.sau.com.au/forums/topic/221612-playstation-3-as-a-dvd-player/
pfft i watched countless movies on my xbox 1 and got it on launch day it never had a single hiccup.
I would really reccommend a ps3 as a dvd/blu ray player they are really good.
However i dont know what its life span is, the ps2 sucked bad as a dvd player cause of a shitty laser. I would bet the ps3 would have learnt its mistake and it looks like they has the best entertainment player on the market at the moment.
It is true they dont last forever, But fortunatly the Laser diodes can be easily replaced with a new one. No need to stress about playing DVD's on your PS3.
Im certainly not an electronics expert so this may seem like a dumb question, but... How would someone get the diodes replaced if they needed to?
Theres a guy in conder who im 95% sure could fix it... PM me for the details if you want them.
The laser in the ps3 wouldnt be reading much differently on a dvd than it would a blu ray (for games etc)... same goes for xbox 360 games and dvd's... if you cant play a dvd on a dvd player (which is what both the 360 and ps3 have) as much as you want, then its pointless... so i dont know how much truth is in "the more you play dvd's, the more the laser dies" story... i would almost guarantee its just the general life of the laser in your dvd player, or just needs a thorough clean...
Edited by SKYLVIA
ps3 and xbox are dvd players?? r u insane?
So if PS3 and Xbox 360 can both play DVD's perfectly fine, what would you call them? 360 games are on DVD's, and the 360 reads them, and plays them, hence "DVD player"
I know what your saying, that its a Blu-Ray player with capabilities of playing DVD's, but some people really cant be arsed to write "Blu-Ray player with capabilities of playing DVD's" or "A device that can read and play DVD movies/PS2 games (Also stored on DVD's, but only capable on 60gb models)".
Edited by SKYLVIA
Well I dont know, but I must say the upscaler on the ps3 works a charm and the picture was so much clearer than on my mates conventional DVD player.
R u running ur PS3 through HDMI?
Edited by Mayuri Krab
Ps3 native scale is 600p, it upscales to 1080p if the software enables that format
I have my PS3 running directly into my HD LCD screen via HDMI and the 1080P picture absolutely awesome, Ive never seen such a clear image.
I have 2 questions for anyone who considers themselves a bit of a PS3 expert:
1. When I watch DVD's on my PS3, every half hour or so the sound drops out completely for about 1 or 2 seconds, why would this happen? (I have checked all the sound settings and they're all correct and all cables are properly plugged in).
It doesnt do it during game play though.
2. What is an "upscaler" and why would you use it?
1. Difficult to answer without more info what sound system do you have, if its a 5.1 system it might be from lights getting turned on and off which can interfere with the frequency but it could be many other things. Just ceck your connection and make sure you have the sound settings set right for your system.
2. Upscaler is automatic, ps3 is 600p. If a game supports a higher scan then the ps3 will up scale to its optimum.
example if the game says on the back 720p/1080i/1080p it can run at 1080p max but that will be upscaled from 600p.
Thanks for that Pat,
Its not a light switch problem.
Im running the sound from the LCD to my stereo amp witch is 2 channel only, its an older HI-FI set up with all individual units (amp, graphic equaliser, cd player etc are all separate) and the setting on the playstation is for 2 channel linear 48khz which was the auto set when I set up the sound options...
I'll have another look at all the cables and see if they arent kinked or not connected properly but Im pretty sure that they're all fine.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
