hey guys, just wondering if anyone can tell me what i can do to my car, for a bit more extra power, its a nissan pintara trx SSS 1990 ka24e car.
its got forged pistons, light flywheel, bigger cams and throttle, bigger exhaust, extractors, CAI.
now i was thinking, maybe new headers? the ones on it r only like 2 inch and there small. would new, bigger ones do anything?
how about a fuel pump?
lighter head gasket?
maybe a bigger cam?
i would love some ideas on this, because im going to go get it tunned after i do some more work to it, its currently doing 135kw @ wheels.
https://www.sau.com.au/forums/topic/221886-more-powa/
why are you asking these questions when you have forged pistons??? if it's been rebuilt it should have been done the first time and done correctly.
the formula for any well powered NA motor is: quality of fuel + compression ratio + intake and exhaust efficiency + tune = :blink:
fuel pump and a reg will supply the fuel, but any power increase would be negligible.
lighter head gasket? i've never heard of one of those. if it's a thinner head gasket then you'd be looking into compression ratios.
a cam(shaft) will increase your motor's ability to breath, if you're chasing more 'power' at the cost of driveability - then i say rev the thing right out.
here's what you do:
- find a good tuner
- find a good mechanic
- sit down with both of them and nut out what application you are using the car for and adjust the compression ratio/fuel quality availability to suit
- tear the entire motor down
- forged rods
- replace forged pistons if need be to achieve desired CR
- skim the block or head if need be
- port and polish the hell out of the head
- deshroud the valve ports, oversize the valves, upgrade valve springs
- regrind/new camshaft to suit tune/application + cam gear
- balance bottom end as an entire package (ati/ross tuffbond balancer, crank, rods, pistons, flywheel) & knifeblade the crank as much as you can. lighten wherever and whatever you can
- good quality sparkers, injectors, fuel system.
- motec/autronic/pentium 4/etc. take your pick
- custom tune length headers
- tune tune tune tune tune
- have a deep wallet
- nitrous/forced induction
problem is you will need revs to make power, and with revs comes wear and wear = longevity.
i will leave this open in the meantime, however i suggest you try to search around the forums and see what everyone else does for their RBs and see what you can apply to your motor. the principals are the same, however the characteristics are not. try searching for a forum more specific to your car for more detailed responses.
135 at the wheels is impressive. good luck!!
p.s. - is the twin cam head conversion do-able? might be something to look into
https://www.sau.com.au/forums/topic/221886-more-powa/#findComment-3910780
2" Headers are what we use on Blown V8s and 1 7/8" for NAT Atmo, 2" primary pipes are HUGE even on a 383+ cube V8
Definatley would want to see eveidence of power figures and strip times.
As for going harder basicly as EUG said. only other thing I could think of would be ITBs but i doubt anyone has an off the shelf ITB kit for a KA24e...
https://www.sau.com.au/forums/topic/221886-more-powa/#findComment-3915121
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
