Hey guys, just a few items that have been sitting in my shed or room for a while now. Make an offer or better yet just call me and make a deal on 0423734866.
Items are located in South Australia (Just of Anzacs, for those in SA =)) Inspection more then welcome.
Item:Genuine Nissan Badge
Age:15 years?? not sure.
Condition:6/10
Price:$15
To Fit:Any car you want to put it on.
Comments:Its just a badge and has been sitting around for ages. It has marks and scuffs.
Item:Turbosmart Bleed Valve
Age:2 years?.
Condition:9/10
Price:$40
To Fit:Any car with a turbo (I had it on my r32 rb20 running 11psi.
Comments:Other cheapo brands of bleed valves are known for spiking.
Item:FET Turbo Timer w/r32 harness
Age:2 years.
Condition:5/10
Price:$30
To Fit:I had it on my r32 and was working when removed.
Comments:Removed as i had to go through regency.
Item:Tie Rod Spacers
Age:Brand New!.
Condition:10/10
Price:$30
To Fit:R32GTST
Comments:Purchased this a while back and never got around to fitting it. Installing this will give you extra degree in full lock. Essential for drifting. Also comes with instructions on how to install, step by step.
Item:Turbosmart Blow Off Valve Plumback Version
Age:3 years.
Condition:8/10
Price:$200
To Fit:Any car. I had this on my R32.
Comments:I also had this removed as i had to go through regency. It is very loud when not plumbacked, but sounds awesome.
Item:Genuine Kazama Adjustable Castor Arms
Age:Brand New.
Condition:10/10
Price:$300
To Fit:Was planning to fit to my R32 GTST
Comments:These are genuine Kazama Adjustable Castor Arms. Purchased from Tokyo Autosalon whilst they were on sale. All bolts are still sealed in their original packaging.
Item:5xT10 Dash Light Leds
Age:Brand New.
Condition:10/10
Price:$20
Comments:I purchased these off of 666DAN on ebay who also sells the same ones on SAU.
Plenty more pics so just ask =)
Thankyou for looking. :P
Edited by Min_R32
https://www.sau.com.au/forums/topic/222003-nissan-r32gtst-skyline-parts/
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
