  • Replies 260
ok...we will be calling a meeting, hopefully at the end of next week, where we will talk, and hand out the entry forms that i just put together amd used all my printer ink on!
hope is not lost! SAU Will still have a top display this year!
If you need printing done, just email it to me and ill print it at work :P willing to help you guys out, id be there but i have committed elsewhere. Im a part of SAU, i wanna see how god the display can be!
Edited by Damo_R34
^^^ could have told me that half hour ago! not-happy-damo!
lol, oh well.
can ya ateel a printer cartridge for cannon pixma 6210d? lol
lol unfortunately not, but Bunny33 works at Phoenix Toner, she can hook you up
As i said earlier i've got a V35 but don't know if it will have rims etc by then.
I'd love to see a 35 in there, and you are more than welcome to join us.
Do 35's have the same stud pattern as other skylines? if so perhaps you could borrow a set of rims for the weekend from either a store or another club member.
PLEASE ALSO BE ADVISED THAT WE HAVE TO HAVE OUR PAYMENTS/ENTRIES IN BY JULY 25TH
OTHER WISE THE ENTRANT FEE IS DOUBLED! cost per car in club display is $90 BEFORE 25TH JULY.
obviously we will haved to budget a little higher than that, for flooring/lighting etc.
anyone spoken to pat(pk blade) lately? he might be keen again, havnt seen him on here for ages.
Ummm trying to think of others, martin, you not keen to enter HOSTILE again?
guy, you not interested in putting yours in?
Nah mate, get back from vanuatu on the friday setup day... too hard for this year.
if there hot and willing to pose then yes.
and let me know wen this meeting is,
i mite enter as long as everything runs smooth
and also rims, well speak to me if you want to work something out
i just bought those from japan for the shop and also got some major dished 18's coming aswell, and will help people if they contact me and we work something out.
Edited by JDM032
;P wont know till they arrive, but i plan on using them if my car is entered.
18x9 18x10 with like 15 offset or less, sumthin like that
or these 18x9.5 and 18x11 with like +6 offset
i just dont know which ones i want yet lol
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
