Hey all just thought i would share my recent experience at Willall racing. After waiting a good 5 months for my Power FC it was time for a tune (see mods in my signature). When i called Willall and spoke to Gareth i was actually surprised that i got the car in so quick, 3 days to be exact. Drop the car off on Monday spoke to Martin briefly and told him i was after a nice safe tune and left the car there. Returned 2 hours later and to my surprise it was parked up and waiting for me.
I tell ya what Martin sure knows his stuff because the car pulls like a cut snake right through to redline and all on 10.5psi. So a big thumbs up for Willall Racing if your thinking of getting a PFC tuned in your Skyline.
Lee
https://www.sau.com.au/forums/topic/222346-power-fc-in-and-tuned/
201rwkw seems about right for the power/mods.. Top work. :)
You'll be used to it within a week or two and start thinking about the next round of mods. That GT30 turbo or something of the likes.
Care to share how much u were slugged for 2hrs on the dyno?
Lets just say i have no change left from $2000 after purchase of computer and install. Money well spent in my book best upgrade i have done yet.
I hear what your saying about getting used to the power but i think i have spent enough at this stage. Give it 6-12 months and i will be looking at upgrading turbo etc.
nice looking car :D i was there monday with the 2 s15's.
Martin sure does know his stuff and that new dyno is awesome, finally showing correct figures
Oh that makes sense now cheers for the comment. What did the S15 have done and what power did it make there if you don't mind me asking. Both cars were very nice indeed got a bit of a soft spot for the S15's.
the one with the kit had. Nismo 740cc injectors, HKS/Garret GTRS, profec B boost controller, greddy plenum, greddy suction kit. That made 200rwkw with a slipping clutch, martin said it should make roughly 220-230+ with a better clutch.
the other made 189rwkw with everything except the turbo and plenum.
The boost controllers were mucking around abit. Martin suggested a new wastegate spring/ actuator. They werent holding boost.
Thats nice power to weight must feel good on the street, thanks for sharing that info. The skyline made 197 on his dyno and 201 on Aussies at Hindmarsh which i thought was very close considering ones a mainline and the other is a Dyno Dynamic.
martin is a top bloke! got mine tuned with him, pulled out around 185kw on 12 psi! not to fussy about the figure but he gave it alot more bottom end which i asked for! at the end of the day i was really happy with how the car goes!
Edited by nos man
Mid range was the main reason for buying the power FC because the standard computer wasn't overly endowed in that area.
thats a very good figure!! top stuff!! i might take mine there for a retune... when i had my pfc mapped and tuned i only made 200awkw on 14 psi.. it was a reletively safe tune but still i tihnk i got a low reading! is their dyno 4wd or 2wd??
hopefully see ya out and about dude! thanks for sharing your experience and a good reccomendation
:D
:P
Hey mate i didn't actually go into the shed but from memory it is a 2WD dyno from what i recall seeing. I'm sure 200awkw would be nice in a 32GTR nothing like traction.........Would be good to catch up on a cruise or something thats for sure.
good figure champ,
good to see my mates dyno at aussie's is fairly simular to the brandnew mainline at willall.
Ryan how are ya mate from what Michael told me your beast is now running some extra boost and making excellent power. Aussies dyno does seem pretty spot on thats for sure, i know of a gen3 pulling 208 at Aussies and then pull 224 at another place with nothing changed. Should catch up for a cruise in the near future.
I am going to go down the road of a RB20 ecu being remapped to my RB25.....with an ebc low boost on 10 and high boost on 13......would be interesting as to where that comes up as to your powerfc mate......
yea champ! 250rwkw on 14psi. Very usable power aswell...thanks mate we'll have to catch up.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
