Hey guys,
Got a few random bits for sale, some off my R34 GTR V-Spec II and some other stuff from my last R33 GTS-T.
1. Apexi Pen Style Turbo Timer
Was pulled from my R34 GTR by Chris Rogers when i had an alarm installed. Comes with everything you would normally get, no marks or scratches.
New - $135 // Asking - $90
2. EBC Greenstuff Brake Pads (Front and Rear)
Was going to put them on my R33 GTS-T but i never ended up installing as i sold the car. They are brand new in the box never used.
Paid around $500 // Asking - $350
3. Z32 AFM
Was meant to be installed in the same R33 GTS-T but never got around to it. Item has done approximately 20 hours work before i purchased it, never been installed whilst i owned it. Was pulled off in perfect working order.
Asking - $220 Posted.
4. GTR Injectors
Pulled from my R34 GTR V-Spec II due to upgrade. Its a 2001 model with 50XXX Km's so they have not done to much work. Perfect working order
Asking - $350 Posted.
5. GTR Fuel Pump
Also pulled from the R34 GTR, done the same amount of work as injectors and in perfect working order.
Asking - $150 Posted
6. R33 GTS-T Series 2 Wiring loom
Purchased to redo my R33 before i sold it, never got around to using it. Perfect condition, couple of modified wires for a stereo head unit otherwise completely intact.
Asking - $200
Might add more soon, thats all for now. Will up some pics when i get home.
Contact - PM or SMS / Call 0419741040
Edited by Got Boost?
so hwo good is the z32 afm, if its only doen about 20hrs of work it must be like brand new, please pm me more info about it, are you negotiable on price for it posted to melbourne, pm me details, pics and your best price,
chers tony
Can't edit original post but wanted to add - I will swap parts for an AVCR or E-Boost 2 also.
when you say wiring loom, is that the engine loom aswell, or just the in car loom?
Ill check that, and add a pic!
  • 3 weeks later...
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
