  • Replies 40
Posted Images
haha goto love Jap cars and jap shirts.. if will was jap id love him too lol ...
Nice pics will !!... must admitt i was a hoon a week ago on the highway with my audi.. hehe
P.S see sign behind cars .. Best Parking for ... Skylines or maybe Hoons .. it was funny the guard asked if we were from Boostcruising
Micheal... Thanks for a good nite :) you know what i mean .. Valvoline ....
Edited by 53XYN
Trust me vish, it was my pleasure!
signed up to boost for your lancer yet? Username: SIKLANCR69 :P
Edited by hojak
arrm.. his a Drug dealer .. thats Willi's new toy secretive i must add... except when he hoons up and down logan road ! you cant miss the scream of V10
Micheal , nah i wouldnt FIT in man i need a Evo 9 badge's rallyart stickers all over the car , rallyart seat covers ! , FAT 2" cannon , 17" fully sick mags drift tyres , 500$ thumpin audiobhan system ! etc.. still have a long way to go.. god i miss my rs4 :) ..
P.S not to mention the Fluffy handcuffs ! or dice hanging off the rear view mirror
thanks guys for the photo comments, noticed that the model lined up was like this .. 34 33 32 33 34 !! :P
and this is why my sat was fkin awesome.. :):)
haha thats funny, i didn't even notice we were that order....i mean..yeah i knew all along. haha. So Will, what's the story with the lucky lambo? Don't tell me you bought it.... :P
Micheal , nah i wouldnt FIT in man i need a Evo 9 badge's rallyart stickers all over the car , rallyart seat covers ! , FAT 2" cannon , 17" fully sick mags drift tyres , 500$ thumpin audiobhan system ! etc.. still have a long way to go.. god i miss my rs4 :blush: ..
Mate, ur lancer sounds fully sikkk bro! haha!
Real bummer about ur rs4 vish, sucks. At least you didn't lose out too much and you got out ok...damn hoon. haha
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
