After a relatively short period of ownership, its come time for me to sell up and start looking at track cars
This car is a pleasure to drive, crazy amounts of grip, bullet in a straight line and heaps of room and comfort inside. The tiptronic auto suits the torqey motor well, give all the boguns the fright of their life at the lights when you blast ahead. Engine oil/flush, transmission oil/flush, radiatior flush/change, transfer case oil, diff oil, AYC oil, and plugs have all recently been done, so its ready to go.
Item: Mitsubish Legnum VR4 Type S
Year: 1996
Transmission: Auto - Tiptronic
Condition: Overall good, minor drivers seat leather wear, also some wear on steering wheel and mild dodgy jap touch up paint on front bar.
kms: 74,xxx km
Features: 4WD 206kw 2.5L twin-turbo V6, Moonroof, Airbags, MMCS (touch screen climate/stereo control, jap tv/satnav/AV input), Tan leather with woodgrain dash inserts, Active Yaw Control (same system as evos except latest models), Active Stability Control, Traction control, 17" Stitch Mesh wheels.
mods: K&N Panel filter, 'High-Flowed' Stock exhuast, boost controller.
Reason for sale: Want a track car!!!!
Currently Registered: YES!
Price: $15,000ono
Contact: Bart - 0400 996 966
Photos to come this arvo
https://www.sau.com.au/forums/topic/222446-1996-mitsubishi-legnum-206kw/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
