  • Replies 153
yeah hehe last time i went past ice gerald said: like my daily driver
god damn!
whats with this pic?
http://www.the-silo.com/james/gor_album/im...es/DSCN3276.jpg
next time there is a cruise to gor i will go definately i was busy on sunday which was a bitch :thumbsup:
ApacheX,
I can send you one, but it's at least around 30+MB
The only regret I have is I should have taken MORE photos, as when we finished the cruise at Apollo Bay, I still have plenty of space in my flash card for at least another 20 shots :thumbsup:(((
Originally posted by ApacheX
rs73, u got a zip file of all the pix by any chance?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
