Item:
R33 GTR rims 17 x 9 + 30
Unknown
Condition:
Very good
Price:
$1,300 + freight anywhere
To Fit: (What car)
Most cars or anything 5 x 114.3
Melbourne - south eastern suburbs
Contact:
PM
Call/SMS 0416 623 381
Email/MSN [email protected]
Comments:
Up for sale is a full set of forged 17 x 9 + 30 R33 GTR wheels
These are some of the lightest rims I have ever seen, for the size and width they really weigh a sweet f - all!
The rims themselves are in pretty good condition, they have some minor marks as expected for the age but overall they are in very good condition
Tires up front are literally brand new, I have probably done about 200km MAX on them, you can still see the chalk on them from the factory lol
I am unsure of what brand they are, something like V001 but they are a very good tire for street use and grip awesome up front
On the back I am running FEDERAL EVO 595 tires which are from FEDERAL tires motor sports range. 595EVO tires are from the competition series that FEDERAL offer and are one of the best competition tires from the FEDERAL range.
http://www.federaltire.com/en/html/pdetail...line=1&ID=2
Back tires are currently at 70% + tread so are more than roadworthy. Tire profiles are 215/45/R17 all around so they are slightly stretched for a 9" rim but look great
These rims fit perfect onto an R32 with standard guards - no rolling or flaring required
Please don't post comments in the thread, PM if you have something to say - Genuine interest only please.
If you have any questions feel free to ask
https://www.sau.com.au/forums/topic/223131-r33-gtr-rims-near-new-tires/
ill make you a offer of $900 pick up its a lowblow but i can work out a deal also intrested in a set a 19"s
im the dude u bought the bride R34 rail of a few months ago
PM sent
Hi mate,
I thought U sold it and got the 34GTR wheels on ur already...
it's perfect wheels on 32gtst and good price too
Ford
Hey man
hehe you can't always believe what you read :P
I will consider swapping for other wheels, if wheels are of higher value I will throw cash on top
Offers through PM or call/SMS
Thanks
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
