So my plan is to build a stroked RB26 and make a torque monster of an engine. Ive read all there is to read about stroker engines on the forum and have been particularly interested in Mark99 and RPMGTR's RB29 builds and their successes in achieving what they set out to do.
This would be my first GTR engine build, though i have all the tools for engine assembly and am not a stranger to assembling performance engines. I will be getting assistance from someone who has built 500kw engines before but intend to do 99% of the work myself. My goals are to keep the RB26 block size to make fitment not a problem. Im aiming for max capacity, highish compression (9:0 or more), and a moderate size turbo system. (2530's/T517z's)
I want monster mid range torque, dont really care about power at the end of the rev range because thats not where most of the driving is done. I will sacrifice top end RPM to gain mid range torque... so i dont have to rev it as hard. It should make 350kw as a maximum goal realisticly. Anymore than that i think is getting a little un-practical for the street. Im planning on using some CP raised pin pistons and a long rod, probably pauter and some sort of aftermarket crank either HKS or a GT500 spec crank. I have access to a great machine shop that can add a 2-3 mm to the crank stroke (80mm max im thinking), and then run a smaller big end bearing in the pauter rods (1.85" rod big end bearing). As its not going to be a huge reving engine i doubt a few mm will reduce crank strength too much that its a worry. 80mm will give 2850cc as opposed to the 2770cc of the HKS/tomei cranks. A real 2.8lt.
Ive done the math on various engine combinations and it would seem (but i dont really know...) the upper maximum is possible around 43-45m/s, with a safe limit of around 40m/s. This was based on an RB26 at 10,000 - 11,000 RPM. This data is assuming a full drag engine of course. I just want reliability for the street so I like to factor in some over engineering. Data from CP about what is safe seems to be hard to come by.
So my questions for the pro's out there that want to share some information...
1. What is considered a safe piston speed, assuming your using a CP piston ?
Ive read that 450hp is a more or less maximum for the 05u R32/R33 block if its driven like a mad man. Above that they aparently have a reputation of cracking along the side of the block due to the block twisting... according to my "search engine results"... is there any truth in this. Who can say...I am not sure whether to build use an R34 RB26 engine as a core, or if I should build a bottom end in a 24U block and just source a complete head instead.
2. Will the 05u support a 350awkw engine that will be making considerably more torque than the average 2.8lt, or should I just get a 24U block and be done with it? What about R34 GTR blocks...?
3. Engine assembly tolerences. When assembling engines of a "built" nature, are all the specs kept to be fairly standard, or is are a few of the tolerences loosened up a little, such as main and big end bearing clearences to improve oil flow and bearing cooling etc? What about changes to end float thrust to allow a little more oil flow , so the thrust bearing isnt carrying too much load from that heavy clutch when your foot's on the pedal and your about to launch?
4. What about piston - bore clearances? Does everyone generally machine their blocks for 87mm if using an 87mm piston (assuming the piston manufacture's built in clearance 0.003" or whatever will be ideal)?
5. Internal engine parts coatings.... Specifically teflon coatings for the piston side skirts to reduce piston/bore wear due to the nature of the stroker engines having more piston rocking. But also teflon coatings for main and rod bearings, and ceramic coating piston crowns. Ive had competition coatings in brisbane do coatings for quite a few engine parts for me, but ive not heard of the GTR croud getting in on this yet. I figured I'd give the ceramic crown coatings a miss due to the RB26 having oil squirters for piston cooling so why bother with ceramic coatings, but what is the general concensis on teflon coatings?
I think thats about it for now. Im sure there will be many more questions to come.
Cheers,
Ian
Edited by Vspec R33
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
