Well, I dont really see the point of the before dyno,
its completely stock, and I mean completely.
And depends on how much a dyno costs. it would be nice to know, but knowing doesnt make the car go any faster.
  • Replies 65
Posted Images
depends where you go...
well, then no point for a dyno i think. if you have a completely stock non-turbo, i guess you could run off specs.
say 147kw/96rwkw? Or however much power the gt-v holds.
They are made for the R34, but will fit any other RB25 motor. Not sure if the RB20 is the same design or not.
So if you have a R34, they are a good option.
Not sure if the cobys were designed around a particular model or not.
How much would it cost to install the extractors ? EUG or Shane, got any ideas?
Because i would be pretty interested, but i doubt i'll be hitting it up in a group buy, because whenever there is a group buy im short on the dosh, but when there isnt i got an influx of it in my back pocket lol.
MRXTCZ
It would probably take about 2 hours to fit. so allow at least $200.
You could also try it yourself, no welding required for fitting the extractors for the 34's, all bolts. Just be careful not to snap any of the bolts on the side of your block.
dont think there's a need to take out the engine lol.
going to wait for Trevor's results then make a decision on a possible group buy.
Trev, i'll try and go through with you all the points that Eug raised earlier so i can post em up in here, or if you're keen just throw us some feedback.
Cheers.
Ohh. is it just bolts?
Do i need to crane the engine out to get them in? If not i'll do it myself and get my dad to give me a hand aswell!
thats great news lol!
MRXTCZ
LawL, god no, you dont need to lift the engine out, that would take you all day just to disconnect everything.
take out the airbox and all connecting pipes, then you should be able to see the current exhaust manifold covered in a heat shield, take the heat shield off, undo the cat first. (good idea to use some ramps or at least a jack and supports).
I think there is some stuff you can put on the bolts that will help lossen them. it also helps to tighten the bolts slightly before you try to untigthen them.
once its all off, clean up the block with a wire brush, or better still get a drill attachment wire brush.
replace and rusted nuts. if you have the tools you can replace any rusted studs as well.
you can also use some high temp gasket goo on the gaskets to give a good seal.
Bloody oath!
This thing is friggin massive and deafening man!
I need to get a smaller cat back. 2.5 or 2.25 hmm.
Need to get that before i even thing bout getting extractors on mah ride.
I saw the extractors on ebay aswell.
MRXTCZ
What do you reckon the power advantage would be like? (kw wise)
MRXTCZ
Theres a fair bit more down low toque.. The engine is happyier to be at lower RPM.
I also noticed that the engine reved out quicker and a little harder.
There wasn't much top end again. So there wont be much of a "kw" gain as there isn't much (if any) top end gain where the "peak kw power" is recorded.
It will however give you more responce and a slightly wider power band. You will be able to the diffrence on a dyno sheet. The curve will "bulge" earlier (giving you more torque) where there previously wasn't.
Dont expect too much from it. Do bear in mind that it is only a small section of the exhaust. Your whole exhaust is as good as its worst bit. You may find that the rest of the exhaust system will need to be replaced with a better flowing mandrel bent 2.5 system to see the full gain of the extractors.
P.s. I noticed that the exhaust became a little quiter aswell. Other users have reported otherwise though.
Ahh i see, cheers for the info man.
Well, i really wasnt expecting much anyways, im thinking i'll start from the top and work my way down for the exhaust. Extractors, CAT, then cat back.
Hmm, should be seeing some gains, coz i knw for a fact im loosing power / compression with the massive 3 or 4" i got on the NA right now. Waiting for my group certificate and lovely tax return hehe!
MRXTCZ
MRXTCZ
Aren't we all!! :) I'll probably get the whole exhaust system done in one go, once that lovely tax return comes through hehe
I'm still keen to see the results of these DKNE extractors though.
Getting more top end power is good, but for daily driving, I'd prefer having more useable power and better response.
keep in mind guys that top end power can be achieved with a larger exhaust, which means more air is required to attain optimal exhaust efficiency. more air = more revs. unless you are revving out to 6-7000rpm daily i doubt you'd make use of the high power reading.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
