Well, I dont really see the point of the before dyno,
its completely stock, and I mean completely.
And depends on how much a dyno costs. it would be nice to know, but knowing doesnt make the car go any faster.
  • Replies 65
Posted Images
depends where you go...
well, then no point for a dyno i think. if you have a completely stock non-turbo, i guess you could run off specs.
say 147kw/96rwkw? Or however much power the gt-v holds.
They are made for the R34, but will fit any other RB25 motor. Not sure if the RB20 is the same design or not.
So if you have a R34, they are a good option.
Not sure if the cobys were designed around a particular model or not.
How much would it cost to install the extractors ? EUG or Shane, got any ideas?
Because i would be pretty interested, but i doubt i'll be hitting it up in a group buy, because whenever there is a group buy im short on the dosh, but when there isnt i got an influx of it in my back pocket lol.
MRXTCZ
It would probably take about 2 hours to fit. so allow at least $200.
You could also try it yourself, no welding required for fitting the extractors for the 34's, all bolts. Just be careful not to snap any of the bolts on the side of your block.
dont think there's a need to take out the engine lol.
going to wait for Trevor's results then make a decision on a possible group buy.
Trev, i'll try and go through with you all the points that Eug raised earlier so i can post em up in here, or if you're keen just throw us some feedback.
Cheers.
Ohh. is it just bolts?
Do i need to crane the engine out to get them in? If not i'll do it myself and get my dad to give me a hand aswell!
thats great news lol!
MRXTCZ
LawL, god no, you dont need to lift the engine out, that would take you all day just to disconnect everything.
take out the airbox and all connecting pipes, then you should be able to see the current exhaust manifold covered in a heat shield, take the heat shield off, undo the cat first. (good idea to use some ramps or at least a jack and supports).
I think there is some stuff you can put on the bolts that will help lossen them. it also helps to tighten the bolts slightly before you try to untigthen them.
once its all off, clean up the block with a wire brush, or better still get a drill attachment wire brush.
replace and rusted nuts. if you have the tools you can replace any rusted studs as well.
you can also use some high temp gasket goo on the gaskets to give a good seal.
Bloody oath!
This thing is friggin massive and deafening man!
I need to get a smaller cat back. 2.5 or 2.25 hmm.
Need to get that before i even thing bout getting extractors on mah ride.
I saw the extractors on ebay aswell.
MRXTCZ
What do you reckon the power advantage would be like? (kw wise)
MRXTCZ
Theres a fair bit more down low toque.. The engine is happyier to be at lower RPM.
I also noticed that the engine reved out quicker and a little harder.
There wasn't much top end again. So there wont be much of a "kw" gain as there isn't much (if any) top end gain where the "peak kw power" is recorded.
It will however give you more responce and a slightly wider power band. You will be able to the diffrence on a dyno sheet. The curve will "bulge" earlier (giving you more torque) where there previously wasn't.
Dont expect too much from it. Do bear in mind that it is only a small section of the exhaust. Your whole exhaust is as good as its worst bit. You may find that the rest of the exhaust system will need to be replaced with a better flowing mandrel bent 2.5 system to see the full gain of the extractors.
P.s. I noticed that the exhaust became a little quiter aswell. Other users have reported otherwise though.
Ahh i see, cheers for the info man.
Well, i really wasnt expecting much anyways, im thinking i'll start from the top and work my way down for the exhaust. Extractors, CAT, then cat back.
Hmm, should be seeing some gains, coz i knw for a fact im loosing power / compression with the massive 3 or 4" i got on the NA right now. Waiting for my group certificate and lovely tax return hehe!
MRXTCZ
MRXTCZ
Aren't we all!! :) I'll probably get the whole exhaust system done in one go, once that lovely tax return comes through hehe
I'm still keen to see the results of these DKNE extractors though.
Getting more top end power is good, but for daily driving, I'd prefer having more useable power and better response.
keep in mind guys that top end power can be achieved with a larger exhaust, which means more air is required to attain optimal exhaust efficiency. more air = more revs. unless you are revving out to 6-7000rpm daily i doubt you'd make use of the high power reading.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
