yeah steve. I told u b4 its Chris Miltons. You got a qoute from them by memory, but it was too much? Interesting though - I have heard (on good authority) that the same work I'm getting done would've costed anywhere up to $1100 from another engine developers. Chris is pretty cheap - but it does save u to take the head off yourself :D
  • Replies 49
Hi All,
Head portings going well if slowly :)
I've been told that you should use an 80 grit sander for the final finish on the inlet port to promote fuel/air mixing but it looks a bit rough to me. Does anyone know if thats the correct finish for aluminium ? ;)
I remember a while back i wanted to do this to my car. Basically i found out alot of good info on techniques and such. What i would personally do is go to some place which has old engine heads for scrap, and use it to practice the correct techniques. That way when it come to ur real head, u shouldnt have too much trouble.
Also A dremel i find is the perfect tool for this.
Funny you guys are on the subject cuz Im in the process of redoing my rb26 head. Im going through the head and porting and cleaning up the combustion chamber for better burn. Now, for the humps on the exhaust side, my theory on those is smooth them out as much as you can. If you were to run into a stud the worst that could happen is that you would have a very small exhaust leak through the stud itself (very unlikely). But it will pay nicely with power increased and better spool up too.
Chris milton ported and polished up both the inlet and exhaust ports. He said some thing about concentrating on the bowl area.
He also cleaned up the combustion chamber so that the air was able to flow in to the cyclinder a little easier hence removed material and then polished that up also. On the Inlet valves he did a 3 angle valve job I think it was and on the exhaust he did a different valve job which made everything really round. I'll find out the exact terminology.
It ended up costing a little more than anticipated as he forgot to mention that its extra to shim the valves when setting up the hydraulics, not sure exactly but u get the idea.
Finished the head now and pictures will follow shortly.
The porting was all done using a cheap air powered die grinder and a Standard Abrasives porting kit. Took me 3 days to do it but I reckon I could do one in 1.5 days now I know the areas to concentrate on. Hope this information is useful to everybody :)
Originally posted by -Joel-
damn.. My camera won't take pics that clear..
What camera are u using?
Its a Fuji S602 camera I think, its not mine its a mates.
I just edited the thread with a load of pictures and a description of what I did but its been rejected :) .......I'll do them as seperate posts.
The original exhaust port showing the intrusive port bumps
The finished exhaust ports....
From the combustion chamber side....
All of the intrusive exhaust port bumps were removed the ports were enlarged to the exhaust manifold gasket.
All casting marks were removed.
The divider was knife edged and the valve seat area was blended into the bowl.
The 'short' side of the port was radiused as there is a fairly sharp edge where the port turns into the bowl area.
The exhaust ports were finished with a finely polished shiney surface to slow carbon build up.
Standard inlet port....
Finished inlet ports....
The inlet ports are very well shaped in standard form and have 3 angle seats as standard.
Inlet ports were all enlarged to the inlet gasket.
The area where the valve seat meets the bowl was blended smoothly and all port casting marks were removed.
The divider was knife edged and the ports were finished using an 80 grit sanding roll to promote good fuel/air mixing.
Combustion chambers......
All combustion chambers were smoothed and polished thoroughly to reduce the likelihood of detonation and also to slow carbon buildup.
The combustion chamber shape has not been changed at all so compression ratio should be unnaffected.
  • 1 month later...
If you didnt have to buy a new head gasket when you remove the head i would grind and polish it all up myself... bit of a pain .. maybe one day when i need to rip the head ill do it ...
I got a question, ive got my exhaust manifold off at the moment and i was wondering if its a good idea to grind and smooth the inside of the manifold since its off anyways?
Another question i got is on the manifolds turbo outlet there is a divider in the middle that seperates the pipes - OOO|OOO -
anyone know if i can play around with that ? eg. like make it a knife edge or totaly remove it ... It has a slot in the middle of the divider as well ...
oh and make sure you don't go to thin as it will crack. Get a pinch measuring tool to check wall thickness. don't go under 2.5mm.
Also some of the bumps near the outlet are purposeful to direct the airflow around a the bend, these need to be smoothed rather than removed.
Be carefull knife-edging the outlet as a heat fatigued piece of broken metal will kill your turbo in a second.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
