yeah steve. I told u b4 its Chris Miltons. You got a qoute from them by memory, but it was too much? Interesting though - I have heard (on good authority) that the same work I'm getting done would've costed anywhere up to $1100 from another engine developers. Chris is pretty cheap - but it does save u to take the head off yourself :D
  • Replies 49
Hi All,
Head portings going well if slowly :)
I've been told that you should use an 80 grit sander for the final finish on the inlet port to promote fuel/air mixing but it looks a bit rough to me. Does anyone know if thats the correct finish for aluminium ? ;)
I remember a while back i wanted to do this to my car. Basically i found out alot of good info on techniques and such. What i would personally do is go to some place which has old engine heads for scrap, and use it to practice the correct techniques. That way when it come to ur real head, u shouldnt have too much trouble.
Also A dremel i find is the perfect tool for this.
Funny you guys are on the subject cuz Im in the process of redoing my rb26 head. Im going through the head and porting and cleaning up the combustion chamber for better burn. Now, for the humps on the exhaust side, my theory on those is smooth them out as much as you can. If you were to run into a stud the worst that could happen is that you would have a very small exhaust leak through the stud itself (very unlikely). But it will pay nicely with power increased and better spool up too.
Chris milton ported and polished up both the inlet and exhaust ports. He said some thing about concentrating on the bowl area.
He also cleaned up the combustion chamber so that the air was able to flow in to the cyclinder a little easier hence removed material and then polished that up also. On the Inlet valves he did a 3 angle valve job I think it was and on the exhaust he did a different valve job which made everything really round. I'll find out the exact terminology.
It ended up costing a little more than anticipated as he forgot to mention that its extra to shim the valves when setting up the hydraulics, not sure exactly but u get the idea.
Finished the head now and pictures will follow shortly.
The porting was all done using a cheap air powered die grinder and a Standard Abrasives porting kit. Took me 3 days to do it but I reckon I could do one in 1.5 days now I know the areas to concentrate on. Hope this information is useful to everybody :)
Originally posted by -Joel-
damn.. My camera won't take pics that clear..
What camera are u using?
Its a Fuji S602 camera I think, its not mine its a mates.
I just edited the thread with a load of pictures and a description of what I did but its been rejected :) .......I'll do them as seperate posts.
The original exhaust port showing the intrusive port bumps
The finished exhaust ports....
From the combustion chamber side....
All of the intrusive exhaust port bumps were removed the ports were enlarged to the exhaust manifold gasket.
All casting marks were removed.
The divider was knife edged and the valve seat area was blended into the bowl.
The 'short' side of the port was radiused as there is a fairly sharp edge where the port turns into the bowl area.
The exhaust ports were finished with a finely polished shiney surface to slow carbon build up.
Standard inlet port....
Finished inlet ports....
The inlet ports are very well shaped in standard form and have 3 angle seats as standard.
Inlet ports were all enlarged to the inlet gasket.
The area where the valve seat meets the bowl was blended smoothly and all port casting marks were removed.
The divider was knife edged and the ports were finished using an 80 grit sanding roll to promote good fuel/air mixing.
Combustion chambers......
All combustion chambers were smoothed and polished thoroughly to reduce the likelihood of detonation and also to slow carbon buildup.
The combustion chamber shape has not been changed at all so compression ratio should be unnaffected.
  • 1 month later...
If you didnt have to buy a new head gasket when you remove the head i would grind and polish it all up myself... bit of a pain .. maybe one day when i need to rip the head ill do it ...
I got a question, ive got my exhaust manifold off at the moment and i was wondering if its a good idea to grind and smooth the inside of the manifold since its off anyways?
Another question i got is on the manifolds turbo outlet there is a divider in the middle that seperates the pipes - OOO|OOO -
anyone know if i can play around with that ? eg. like make it a knife edge or totaly remove it ... It has a slot in the middle of the divider as well ...
oh and make sure you don't go to thin as it will crack. Get a pinch measuring tool to check wall thickness. don't go under 2.5mm.
Also some of the bumps near the outlet are purposeful to direct the airflow around a the bend, these need to be smoothed rather than removed.
Be carefull knife-edging the outlet as a heat fatigued piece of broken metal will kill your turbo in a second.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
