omg, i thought this was only happening to me, got a 34 gtt, and the battery has carked it (although recently, its been better than before). i was having a power leak for a while. i get home from work at 6pm, and i start the car in the morning at about 8.30am. atm, the charge when i turn the key is about 11.4v, a while back, i would reach like 10, and sometimes under. sometimes, i would just barely start the car. leaving it for a couple days not driven will need a jump start. my prev battery was from nrma, and they replaced it with another one about 2 months ago. the old one was completely funked.
as in what type are they??
bonnet pin - find it and disconnect it.
hey chris
i think they are called ultrasonice or sumthing. pls see attached pics:
ok it's getting worst now. even if i don't arm the car the alarm still goes off randomly. my motion sensors in the car kicks in after a minute without arming so i'm not sure if it's the bonnet or the sensors now
Edited by hotchoc
Mine has a similar issue, if I don't drive it for more than 6 days the battery goes flat... it's f**king annoying. Secondary alarm goes off until I get enough charge to disarm it and then jump start. Issue was temporarily resolved when I got a new battery under warranty, but within a month the problem returned.
Had the alternator checked at last service and all checked out ok.
I'm inclined to think it's these shitty supercharge batteries (which I didn't fit to the car)... luckily they have a 36 month warranty.
Edited by mrgilly
apparently my previous installer installed the ultrasonic sensors at the spot where rain water will run thru in the car (what at tool!!) - wasn't the bonnet sensor at all.
all it needs is a sensor replacement from autowatch
highly recommend will from alberts myaree who sorted out this problem for me for any alarm jobs.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
