Make: 1988 Nissan
Model:R31 GXE skyline Rb30e+t
Milage:185,000kms
Transmission: 4 spd auto
Colour:white
Complied?
RWC supplied?no
Currently registered?yes oct
Price:$3000
Contact:email [email protected] or pm
Comments / Modifications: running standard rb30 turbo gear ( turbo, manifold, injectors, ecu), custom turbo lines stainless! 2.5" exhaust not loud, comes with brand new black fmic never fitted, cd & speakers, king springs, series 3 front bar, hot plate rear lights. just put new brake pads, bosch coil/leads/dizzy cap on, new battery. for its age its fairly good nic, interior is immaculate, also comes ith brand new turbosmart single boost controller.
Images:heres some pics
Edited by 2BNVS
https://www.sau.com.au/forums/topic/224573-r31-gxe-skyline-rb30et/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
