this is cool, but its in canada, anyone know any shops here that make them for the front?
http://www.rocketz.net/catalog/r32-skyline...ser-p-3563.html
a three piece that bolts up...
its about $200 AUD before shipping
looks awesome... would love one for my 32... do they make a bolt on rear difuser aswell??
the front one would also act as a fixed drip tray for me aswell :P
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-3958110
the front one would also act as a fixed drip tray for me aswell :thumbsup:
i wonder if we could get a couple people and get a shop to buy it in legally and make copies pending our purchase after
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-3959281
A diffuser would have 0 effect on a road car because you wouldn't be able to lower it enough for it to work.
Have a look at race cars; the front spoilers are less than 3cm off the ground.
does that mean Ferrari, lotus, Porsche and even the new nissan GTR had all been designed and manufactured with under body aero-pieces that have 0 effect on the road?
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-4003858
these ones arent to create underbody downforce, rather for leaving airflow under the car relatively undisturbed i think.
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-4009250
  • 4 weeks later...
By increasing airflow speed under the car by streamlining the underbody and reducing drag, dynamic pressure will increase, static pressure will decrease, the end result should be a net downwards 'lift', it should suck the car on to the road, hell im only going off what I have read, what race teams use and my knowledge of aerodynamics.
The rear diffuser needs to allow the airflow to accelerate and rejoin the air from above the car, if that one curves upwards and you have sufficient flow coming from the front the overall effect will be like that of an upside down aerofoil
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-4063636
  • 9 months later...
^^^ this isn't diffuser it's lower lip that attach to the bumpers.
As for finding them, try wreckers or ask nissan dealer to get one from japan for you.
thanks mate, just about every site called them somethin different (front spoiler, splitter, diffuser, lip) whatever they wanna call it!! have been sittin on the net all night tryna find one and no luck.....
cheers again.
https://www.sau.com.au/forums/topic/224741-front-diffuser/#findComment-4606948
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
