  • 2 months later...
well its been awile but i finally have them.
1. fronts fitted nice so wont be fitting spacers
2. rears werent wide enough obviously. but will only need 25mm spacers to look
good.
so all in all im wrapped with how they look :D
now what colour to paint the car... :banana:
Mate, I can't believe you actually purchased +35 offset rims for a car with a widebody. Sorry to burst your bubble, but the fronts are actually more sunken-looking than a stock car. From what I can see, you need 35mm spacers all round.
nah mate i only need spacers for the back as iv measured it . the fronts look wrong because of the stock guard liner that i used.im goin to be ripping that off and making custom ones to fit properly as i made it cover the "vent" part on the inside.when i make them they wont be covered
+35 offset barely sat flush on stock R33 guards... All I'm saying is you have a mad widebody going, and for the price that you purchased those rims for new, you could have gotten yourself some crazy Jap rims that actually provide good fitment.
Edited by mr. kirisaki
well i highly doubt ud beable to get thses to fit on standard guards they will sit 2 - 3 inches outside of the guard!!
and dude that offset is ridiculous. also i looked into that option of 2nd hand rimms
but the cost of getting them reconditioned and not to mention find new tyres for them out weighed the effortand just to add i wanted brand new,
i may have to look into the offset of these rimms a bit closer cos what ur saying is totally different to what im seeing lol
appreciate the feedback tho
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
