just ordered some the other day. should be here on friday
there is a trader on another forum that's selling some for $144 a pair, plus delivery. 12 months warranty. not sure what the quality is like, but am giving them a shot. can pm you the details if you want.
PM pls :D
same forum
upper arms for $144 here
just ignore me being a dick lower in that thread....
should have them in my hands end of this week, if you want to want to have a look at them before ordering.
Hey princess, not sure what your stake in this company is, but I am free to shop around for a better price.
It's your kind of attitude that turns sales away.
So maybe you should just have a quiet cup of "shut the fark up" and stick to events coordinating.
Gold!! :D
and thanks for the heads up too - actually won't be able to get them till end July so I'll give you a yell then and see how you went with yours ;)
yupp those the ones - kinda wondering if i shouldn't just get bushes..
gonna raise the back a little i think and then see how much camber is left
bushes wont cut it zennon, As a regular track goer you definitely need more adjustment thanis attainable from bushes alone. Get the bloody arms and be done with it, :P
well atm i have too much negative rear camber right - but after sau's free alignment - i found out its actually not as much as i thought it was - and wanna raise car anyway - because its too low in the rear - so probably will only need a little bit of adjustment... but yeah - maybe should just go all the way - we'll see
thanks for the links old man :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
