Don't forget there are different types of each. Aus Tein Super Street probably your best bet if you want to maintain some comfort with increased handling. Either that or head to a suspension place and see what they would recommend for your given application.
This is easy if your driving on street and want an upgrade from standard allways go for street type coilovers if you want track then get track coilovers. long story short you will have pain in your ass and up your spine with anything harder than street spec coilovers for daily driven car.
for a street car, coilover choice isnt absolutely critical. different story if its a track car.
how so? no point going aftermarket coilovers if ur not after performance, and a cheap coilover will not only hinder performance, ull get shit ride comfort as well, pretty bloody important for a road car id say.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
