sorry to jack again.
when i sit on the freeway after a while my light HICAS light pops on, or if i go hard through a few corners it lights up... does this mean i have to check the fluids or go get that diagnostic work done??
cheers
rhys
Check your fluid front (under the bonnet) and back (In the boot).
Wheel alignment
Caster and Tyre Rods
Then Diagnostics.
So yeah pretty much what we all have been talking about. Get it check and see how you go.
https://www.sau.com.au/forums/topic/225808-hicas/page/2/#findComment-4009081
Wheel alignment
Then Diagnostics.
just checked both fluids and there full, i'll have it booked in for a wheel alignment and have then check the caster and tyre rods aswell.
so does the light only comes on when there is an issue?
https://www.sau.com.au/forums/topic/225808-hicas/page/2/#findComment-4009395
Yeah, most likely.
I can't think of anything else.
https://www.sau.com.au/forums/topic/225808-hicas/page/2/#findComment-4010595
Yeah, most likely.
cheers for the help, im just trying to get my head round the GTR
- so the hicas light comes on when there is an issue
- 4wd light comes on when it is not in 4wd (fuse removed)
is there any other warning signs i should know??? i just downloaded the 32 gtr service manual so gonna print all 800 pages of that off and have a read soon
cheers
rhys
https://www.sau.com.au/forums/topic/225808-hicas/page/2/#findComment-4010757
cheers
rhys
Well yeah,
you got ABS, HICAS, 4WD, Battery, Exhaust Temp, Hand Brake and Doors.
BTW Exhaust Temp I would not worry about. I was never too sure why they had that. To check how hot the exhaust is maybe..? Yes they do heat up... But if you get an aftermarket exhaust on there then it won't matter LOL!
All the lights that come on in the dash, they are the things to look out for.
As long as you get your car serviced at 5000km everytime, you sould not have any problems.
BTW just check your other fluids from time to time. ie. Engine oil, brake, clutch and radiator fluids (Green liquid in the resivour).
Yeah I have that Owner manual, something like 800+ pages on cd.
https://www.sau.com.au/forums/topic/225808-hicas/page/2/#findComment-4011390
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
